87 ignition contol module problem - JeepForum.com
 1Likes
  • 1 Post By Lifted-04-LJ
post #1 of 10 Old 05-21-2016, 03:05 PM Thread Starter
Lifted-04-LJ
My son is off to the Navy and Left his XJ behind because he was supposed to go out of country. Now he's in Key west and needs a ride so I'm fixing some odds and ends (brakes, speedo, window regulators and such). I went to start it to move it the other day and it wouldn't start. After troubleshooting I got no spark. I replaced the coil with no luck then the ignition control module.
It started up ran great. I started it several times no issues. I went to fixing other problems and tried to start it again. No spark again. No check engine lights or anything just no spark. I can't think that a brand new ignition module failed in 5 min of run time. I'm ordering a replacement but I'm hoping someone has seen this before and can help. the modules are $125 a piece.
Thanks in advance,
Mark
Iamandrewsiler likes this.
2004 LJ, 4.0l, Auto, 35x12.50x15 BFG MT KM2's, 4" superlift, RE SS brake lines, 4.56 Yukons, D44/Detroit Rear, D30 Front,
, Smitty Xrc10, Hi-lift extreme
Lifted-04-LJ is offline
post #2 of 10 Old 05-21-2016, 04:40 PM
PaYankee
Crankshaft position sensor.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #3 of 10 Old 05-21-2016, 08:26 PM Thread Starter
Lifted-04-LJ
I'll check it
post #4 of 10 Old 05-21-2016, 09:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's how:
http://cruiser54.com/?p=50
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 10 Old 05-22-2016, 04:23 PM Thread Starter
Lifted-04-LJ
WOW, what a PITA! But it's fixed! Started like a champ.
post #6 of 10 Old 05-22-2016, 06:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What did it end up being?
post #7 of 10 Old 05-22-2016, 06:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
A really good Dad would do Tips 1 through 5 and possibly 27......LOL.
post #8 of 10 Old 05-24-2016, 09:45 AM Thread Starter
Lifted-04-LJ
It was the crankshaft position sensor. the other parts were 30 years old so replacing them was no real loss other than the expense and headache.
post #9 of 10 Old 05-24-2016, 02:23 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Seriously though, do the tips.
Glad you found the issue!!
post #10 of 10 Old 06-02-2016, 03:54 PM Thread Starter
Lifted-04-LJ
The F#@$%er sat for week and won't start again. I'm working through the tips now. I suspected electrical issues and the FIRST tip is fix the grounds and references the parts I just replaced so I guess I may be on the right track. Wish me luck!
