87 cherokee 4.0 idle problem - JeepForum.com
post #1 of 10 Old 07-19-2012, 06:37 PM Thread Starter
xj34
I am getting an 87 wagoneer limited the Cherokee style and it has a 3.5 re lift and 31s with the 4.0 he says that when he starts it up that it idles rough and dies in park and gear and that sometimes it will idle fine it park and then die when put in gear .just wondering if anyone has any ideas what it could be o and he also said when he got it the egr valve was disconnected
xj34 is offline
post #2 of 10 Old 07-21-2012, 05:47 PM Thread Starter
xj34
Ok got the Jeep today it runs rough when you start it sometimes it backfires and it will spit gas out of throttlebody and when it starts it idles rough and runs very rich really need some help guys
xj34 is offline
post #3 of 10 Old 07-21-2012, 08:34 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check the pipe/hose from the throttle body to the MAP sensor mounted on the firewall. Can't be melted, have any leaks or cracks.
cruiser54 is offline
post #4 of 10 Old 07-22-2012, 07:52 AM Thread Starter
xj34
Alright will check it I think its fine tho could it be the egr valve at all someone mentioned it to me
xj34 is offline
post #5 of 10 Old 07-22-2012, 07:54 AM Thread Starter
xj34
O and also when I hit the gas like pump it or hold to the floor it doesn't change much like it wont Rev up sometimes it dies
xj34 is offline
post #6 of 10 Old 07-22-2012, 08:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Use some throttle body cleaner and spray along the MAP hose especially near the throttle body to check for vacuum leaks.
post #7 of 10 Old 07-22-2012, 08:57 AM Thread Starter
xj34
Alright and if I do it will it die Cuz I know when its idling rough and I unplug it it dies
xj34 is offline
post #8 of 10 Old 07-22-2012, 11:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The idle will change when the spray hits the leak. Go for it.
post #9 of 10 Old 07-22-2012, 01:53 PM Thread Starter
xj34
Alright I will give it a try tomorrow and see if it makes a difference
xj34 is offline
post #10 of 10 Old 07-27-2012, 06:22 PM Thread Starter
xj34
So did some work on it today I have sprayed around all the vacuum lines and no leaks that I can tell and I tried unplugging the iac and there was no change at all when I hit the gas it wont Rev up at all it sometimes backfires if I unplug the map while running it dies what could it be
xj34 is offline
89 cherokee bouncing idle problem jgi187b XJ Cherokee Technical Forum 28 06-19-2015 08:36 AM
1996 Cherokee idle surge/die problem... Julian1221 XJ Cherokee Technical Forum 8 10-08-2009 01:46 PM
cherokee idle problem hockeykid3824 XJ Cherokee Technical Forum 0 05-22-2008 03:10 PM
Rogh Idle in a 90 Cherokee Lmt. Vacuum Problem? kamspy XJ Cherokee Technical Forum 4 04-28-2008 08:29 PM
90' Cherokee Idle Problem ddoffroad XJ Cherokee Technical Forum 7 08-18-2002 12:38 AM
