87-88 XJ axles and possible future owner. - JeepForum.com
post #1 of 4 Old 08-13-2002, 04:39 PM Thread Starter
smitzer
I am looking to buy a jeep currently and read that some 87 and 88 XJ's came with D44 axles. What is an easy way that I can tell if the jeeps I look at have this axle? The answer to this might be obvious, but I have yet to look at one and just want to know what to expect.
Also what other suggestions would you have for me? Are there any transmissions to avoid like I heard about the YJ's? Anything that I am forgetting? I plan to start looking at 4.0l 6's with 5speeds.
thanks for your help!
smitzer
smitzer is offline
post #2 of 4 Old 08-14-2002, 02:46 AM
EricsXJ
The Post man
EricsXJ's Avatar
The d44's would definitely be nice. I think they were included on the jeeps with the towing package so that may be one clue. You could also measure the axle tube? I'd post a pic or a link if I had one but sorry.
Going that old you will be stuck with the closed cooling system, unless the owner swapped it out already. But it shouldn't be too difficult to do.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 4 Old 08-14-2002, 12:57 PM Thread Starter
smitzer
Great thanks.
Any other reasons one would want to select a later model xj? Has the engine/drivetrain stayed pretty consistant over the years?
Thanks
smitzer is offline
post #4 of 4 Old 08-14-2002, 01:11 PM
jpcomanche
You'll want to stay away from the 89 and earlier 5-speeds. They used the Peugot BA-10/5, which is prone to failure. Mid-year in 89 the 5-speed was changed to the AX-15 which is a much better transmission.
If you are set on finding one with a D44 (good luck, they're out there but not many of them), go with the 4 speed auto. It's the AW4 and it's nearly bombproof behind the 4.0L.
1987 Wrangler
1990 Comanche Eliminator
2003 Wrangler Rubicon
jpcomanche is offline
What Axles Are My 2000 Jeep Cherokee Sport Running? (i Have Pics Of My Axles) DylanYazel XJ Cherokee Technical Forum 23 08-31-2009 10:56 AM
Need specs on some XJ axles (YJ owner doing research) sprowley XJ Cherokee Technical Forum 9 09-19-2008 11:16 AM
Possible future Jeep owner/need advice sgrim9 XJ Cherokee Technical Forum 1 10-29-2007 10:03 AM
future owner trying to make plans Bubba46 XJ Cherokee Technical Forum 8 05-09-2005 10:00 AM
potential future cherokee owner.... got a few ?'s jgedmin XJ Cherokee Technical Forum 11 12-18-2003 12:34 AM
