'86 XJ Front Drive Shaft - JeepForum.com
post #1 of 9 Old 08-31-2006, 08:00 PM Thread Starter
hwalkman
hwalkman's Avatar
I have an '86 XJ with a 2.8L (do I hear groans?) auto. D30 with Selec Trac. The front shaft is the CV variety; will another non CV joint shaft fit this application? If so I suppose I will have to post in WANTED. I would be willing to buy an original drive shaft as I do not wheel in the Jeep, it is just a daily driver, that is when it is operational. It is beginning to be a money pit , but the engine has low miles and the Jeep itself only has 119,000 on the clock.
Thanks for reading this post, hope to hear from someone.
Hwalkman
hwalkman is offline
post #2 of 9 Old 08-31-2006, 08:08 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Yours is a GKN style front shaft. I'm not sure, but I believe you can swap the yokes from a newer unit and run a newer front DS.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 9 Old 08-31-2006, 08:14 PM Thread Starter
hwalkman
hwalkman's Avatar
Thanks for the info, I have found that these shafts are available at local parts stores, but the prices are upwards of $230, yikes.
I appreciate the reply.
Hwalkman
hwalkman is offline
post #4 of 9 Old 08-31-2006, 08:20 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Hit the junk yards. I picked up one from a guy here for around $30. Others have picked them up local at various yards in various states for about the same.
Make sure to measure the distance between yokes to get a feel for what length will work.
93 Sport
Specs in Profile.
balloo93 is offline
post #5 of 9 Old 08-31-2006, 08:21 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Pull the yoke or flange that's on there now and get a inside diameter and spline count before hitting the yards. Make sure the new ones will match up.
93 Sport
Specs in Profile.
balloo93 is offline
post #6 of 9 Old 08-31-2006, 08:31 PM Thread Starter
hwalkman
hwalkman's Avatar
I am sorry to say that the local yards around here crush everything that does not move in a short period of time. I most likely will go back with stock and probably will have to pay a chain store the big bucks. Thanks again for the information.
Hwalkman
hwalkman is offline
post #7 of 9 Old 08-31-2006, 10:25 PM
-XJguy-
1992 XJ Cherokee
You do not need to replace the whole shaft, the cup with the bearings and boot is available seperately, I have bought it, the replacement is made by Moog, I believe. GKN no longer makes them for the XJ. I think it was about $100...but I could be wrong it was years ago.
XJguy
86 XJ Pro-touring 3" drop; WARRIOR
92 XJ Off-roading 8" lift; Xnowyte
91 Comanche Pioneer 4x4 5speed stock.
Navigator for Team#11 Hurst/Olds on Spike TV's Bullrun. The real winners.
-XJguy- is offline
post #8 of 9 Old 08-31-2006, 10:30 PM Thread Starter
hwalkman
hwalkman's Avatar
Hey that is an interesting option. I noticed that NAPA sells a shaft that has a U Joint instead of a CV joint that is an exact replacement. But they fetch about $236.
Thanks for the information, I will do a search for Moog.
hwalkman
hwalkman is offline
post #9 of 9 Old 09-02-2006, 08:21 PM Thread Starter
hwalkman
hwalkman's Avatar
Well, I bit the bullet and went for a reman driveshaft. But there is good news, I ordered one at O'reilly and when it came in it was a up graded version that had a U-joint on the transfer case side instead of a CV joint. And the night before I checked pricing with the 3 major suppliers here and Advance had the shaft listed for $208.88 and O'reilly was $232.99. So after a bit of coaxing O'reilly matched the price and it comes with a limited liftime warranty. I thought I would pass this info on to anyone who, like me still likes the oldie XJ's.
hwalkman
hwalkman is offline
No front drive shaft navarremro XJ Cherokee Technical Forum 7 04-02-2009 10:22 AM
Front drive shaft? scupking XJ Cherokee Technical Forum 6 08-10-2008 11:09 PM
Front Drive Shaft Green97Cherokee XJ Cherokee Technical Forum 2 03-21-2007 05:41 PM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 11:09 PM
Front Drive shaft Lost Soul XJ Cherokee Technical Forum 1 05-24-2002 08:09 AM
