Lift
About 6" should do it. You are looking at a very expensive lift. Besides the lift, you will need another drive shaft (ie Tom Woods) 4.5" is more than ample,a true 32" tire will still require a shaft or lowering the tranny which voids out the reason for the lift. Clearance!, another change if you dont already have it are 4.10 gears or higher because you will spin those tires in the wet, and on dry the engine will be lugging, and never getting near the torque peak. All in all make sure the uni-body is in really good shape (heavy rust) It would be a shame to invest about 2k, and then find out the Mj is terminal. Lots of luck, take care
