86 cherokee 2.8 no start - JeepForum.com
post #1 of 25 Old 06-17-2011, 11:11 AM Thread Starter
scottxr400
1986 XJ Cherokee
I was driving to work and the truck just shut off. I got it towed to work. Check and found no spark. Changed the coil nothing returned that got a rotor and cap put that on and still nohing any ideas
scottxr400 is offline
post #2 of 25 Old 06-17-2011, 11:26 AM Thread Starter
scottxr400
1986 XJ Cherokee
Also when I cank it the rotor turns
post #3 of 25 Old 06-17-2011, 02:42 PM
littlehoov
1986 XJ Cherokee
My next guess would be the Ignition Control Module, which I do believe is located underneath the distributor cap.
Looks like this:
1986 Cherokee 2.8 V6, Torqueflight 904 transmission, NP-228 transfer case. 235/75/15 AT tires. Factory tow hooks...thats about it.
littlehoov is offline
post #4 of 25 Old 06-17-2011, 03:03 PM Thread Starter
scottxr400
1986 XJ Cherokee
That's probly under the rotor and everything right
post #5 of 25 Old 06-17-2011, 06:28 PM
chiefbill1959
The control module is under the rotor button. Make sure you have good grounds too. You can take the module to Advance Auto and they can check it for you. Tell them to run the test 3 or 4 times to get it warm, up to operating temp. It's not hard getting the module off. 2 small screws and the wiring. Did you swap to a known good coil? My bro inlaw had the same problem just a couple weeks ago and we tried one I had laying around. It didn't work so we tried another one and it fired right up.
chiefbill1959 is offline
post #6 of 25 Old 06-17-2011, 06:45 PM Thread Starter
scottxr400
1986 XJ Cherokee
yea i got the coil from a auto parts store
post #7 of 25 Old 06-17-2011, 06:52 PM Thread Starter
scottxr400
1986 XJ Cherokee
i had power at all four wires at the coil
post #8 of 25 Old 06-17-2011, 07:05 PM Thread Starter
scottxr400
1986 XJ Cherokee
do i have to remove the pick up coil to get to the Ignition Control Module or is it under the thing that the rotor screws to
post #9 of 25 Old 06-18-2011, 04:41 AM
chiefbill1959
It will be to the front of the dist.., it has 2 screws going thru the it. The screws are like 6 mm. or maybe 8. The picture above is what it looks like but it may be a different color. It also has some dielectric grease on the bottom of it. Don't wipe it off. When I said the front of the distributor, I mean inside it, under the rotor button, on the front side bottom of the dist.
post #10 of 25 Old 06-18-2011, 11:23 AM Thread Starter
scottxr400
1986 XJ Cherokee
cool thanks man going to my job in a lil to check it out
post #11 of 25 Old 06-19-2011, 02:29 PM Thread Starter
scottxr400
1986 XJ Cherokee
changed the control module and its running thanks alot guys
post #12 of 25 Old 06-23-2011, 06:51 AM Thread Starter
scottxr400
1986 XJ Cherokee
The jeep just shut off on me again this time I noticed its wasent really reving I poped it to nuetral and when the rpms hit like 3500 it died but right b4 it back fired now it won't start?
post #13 of 25 Old 06-23-2011, 08:22 AM Thread Starter
scottxr400
1986 XJ Cherokee
Any one know what would be the cause of the control module to keep messing up
post #14 of 25 Old 06-24-2011, 02:54 PM Thread Starter
scottxr400
1986 XJ Cherokee
post #15 of 25 Old 06-24-2011, 03:08 PM
grsmnky1
1993 XJ Cherokee
Did you regrease your new module before you put it back in? I had a few head problems when I owned my 86 with the 2.8. But a valve job solved it quick. If you still getting fire and it won't start now after a backfire check your carburator those are very touchy carbs.
grsmnky1 is offline
Cherokee won't start roblbobx22 XJ Cherokee Technical Forum 8 04-12-2011 07:54 PM
Angry Cherokee Wont Behave..start and die every 30 min! wont start then run 30 later! bcameron1974 XJ Cherokee Technical Forum 10 06-05-2009 01:22 PM
98 Cherokee won't start sometimes meltdown XJ Cherokee Technical Forum 6 12-09-2007 09:46 AM
01 cherokee won't start aggie_wes XJ Cherokee Technical Forum 2 08-09-2007 04:25 PM
Cherokee Will not start Supercharger XJ Cherokee Technical Forum 1 03-21-2003 11:28 PM
