8 inch lift xj - JeepForum.com
post #1 of 14 Old 11-05-2009, 01:18 AM Thread Starter
wonderbrd937
8 inch lift xj
im going to pick up a 95 4.0 cherokee on sunday and i was looking for lift kits and i thought id piece it together...
i found the 6.5 inch leaf spring packs with a 1.5 inch block.
then 8 inch coils for the front. i am going to do a custom front long arm
8 inch shocks
tcase drop
what do i need for driveshafts...sye? or new front driveshaft?
thanks i really appreciate all the help i can get.
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
wonderbrd937 is offline
post #2 of 14 Old 11-05-2009, 01:43 AM
rollincoal
1991 XJ Cherokee
i got a 8 inch on mine,6 inch springs 2 inch coil spacers/ shackels,t case drop, sye kit with tom woods shafts fornt and rear and over the knuckel steering
Lets go JeePin!! 91"cherokee i6 5 speed 8'lift 35's
01' dodge ram 3500 cummins thats not stock-daily driver
rollincoal is offline
post #3 of 14 Old 11-05-2009, 08:23 AM
cr2000xj
Why a tcase drop with the SYE? One of the main reasons for an SYE is so you don't need a tcase drop.
2000 Cherokee Sport-4 inch mixed lift-RE Superflex Arms-Rusty's Springs-RC track bar-Homebrew Sliders and Transfer Case Skids-Homebrew Roof Rack-Disco's-K&N-Fi SSD 10-Cobra CB radio-31x10.50 STT's on D Windows
cr2000xj is offline
post #4 of 14 Old 11-05-2009, 11:33 AM
Luke94XJ
1994 XJ Cherokee
why don't you do shackles instead of a 1.5" lift block? Not that the block will totally **** up everything, but that the shackle will allow for more flex.
You will definitely need longer brake lines, and an sye (not a tcase drop). I think a front dshaft will work in the rear, but the current front shaft length, may not be enough, look at a zj shaft. Definitely get a good trackbar for your 8" lift, you may want a pitman drop, as they are a needed at or around 7.5"
Luke94XJ is offline
post #5 of 14 Old 11-05-2009, 11:41 AM
justanotherjpr
x2 on the shackles instead of lift blocks. Definitely loose the t-case drop. You will need longer brake lines all around.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #6 of 14 Old 11-05-2009, 11:53 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You will need an adjustable trac-bar, one with a new drop bracket that mounts in double shear like the IRO would be best, longer brakelines front and rear, swaybar disconnects for 8" of lift, SYE and most likely a custom driveshaft for the rear, maybe even a longer front shaft, longer bumpstops, and a new steering set-up. What size tires are you trying to run that you need 8" of lift?
xjfever is offline
post #7 of 14 Old 11-05-2009, 01:08 PM
captain_ruggy
captain_ruggy's Avatar
1994 XJ Cherokee
You will also need to address the e-brake cables. They will be pulled tight to the muffler.
1994 Jeep Cherokee 4x4
4.0 HO, Auto, 4dr., NP231, 8.25 rear
6 inches of bastard pack lift, 35/12.5/R15's
Aux. fan switch, homemade BPE's
moved intake, OEM towhooks
Rear disc brakes, JKS disco's
captain_ruggy is offline
post #8 of 14 Old 11-05-2009, 01:19 PM
Luke94XJ
1994 XJ Cherokee
yeh I cut my e-brake cables, they don't seem worth the dough to me at least.
Luke94XJ is offline
post #9 of 14 Old 11-05-2009, 04:20 PM Thread Starter
wonderbrd937
well i plan on making a strict trail rig/ occasional driver.
it would be nice to run 35s but i can live with 33s
thanks for all the help...if i was to bring it down to 6.5 would i still need new driveshafts or just sye?
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
post #10 of 14 Old 11-05-2009, 04:40 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can easily run 35's on 6.5" of lift. You will need the SYE and rear shaft with 6.5" of lift. If you run 33's you can get away with a 4.5" lift, and may not need the SYE just a t-case drop. If it has stock axles you will need to regear for 35's, but can make it liveable on 33's. Really for the 35's a rear axle upgrade, lower gears, upgraded steering, and better brakes would be recommended. You can do it without these but your jeep will not be fun to drive this way.
xjfever is offline
post #11 of 14 Old 01-06-2013, 01:51 PM
thormx77
1991 XJ Cherokee
my daily driver. 8 inch lift, 35's
thormx77 is offline
post #12 of 14 Old 01-06-2013, 02:08 PM
GetLifted
Why did you post that in a 4 year old thread?
GetLifted is offline
post #13 of 14 Old 01-07-2013, 12:06 PM
BlueGerbil
BlueGerbil's Avatar
So you can do the same?
BlueGerbil
BlueGerbil is offline
post #14 of 14 Old 05-31-2014, 05:44 PM
wjjeep3932
i like the large mud lift xj!
wjjeep3932 is offline
Closed Thread
.5 inch of lift adding to 3 inch teamskiawa XJ Cherokee Technical Forum 10 12-25-2014 09:10 AM
Adding 1 inch of lit to 3 inch RC suspension lift jakevisscher XJ Cherokee Technical Forum 2 10-04-2009 05:01 AM
3 inch rough country lift + 2 inch spacers and shackles?? what else do i need. stiffy725 XJ Cherokee Technical Forum 5 10-28-2008 07:31 PM
will 30 inch tires fit on a 2 inch lift without rubbing? woodie416 XJ Cherokee Technical Forum 12 10-03-2008 09:10 AM
request: pics of 3 inch lift, and 31 inch tires wishihad1 XJ Cherokee Technical Forum 17 12-26-2005 02:08 AM
