8.8 Rear End - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 8.8 Rear End
TJ 5.25" Speaker Adapters - NalinMFGTJ, YJ & LJ Drop Down Tail Gate Conversion KitLJ Suspension Systems from Clayton Off Road
Unread 05-19-2014, 09:07 PM   #1
19Cherokee96
8.8 Rear End
I have a 96 Cherokee 4wd with a ford 8.8 rear end out of a 96 ford explorer, and Sye. i went to buy the u joint for the driveshaft all they could pull up was the small ones, the one i need is longer cap to cap on one side. Does anyone know a part number for autozone, o'reilly, advance, etc... i looked on some forums but the part number they gave autzone said they couldnt find it. it doesnt have a flange it has a normal yoke but its longer ( cap to cap ) than a normal yoke. any help would be appreciated!!
19Cherokee96 is offline   Reply With Quote
Unread 05-19-2014, 09:30 PM   #2
Agent620
Could be the 1330 joint.
[B][COLOR="Blue"]Thanks to Anticanman who gave me a membership![/COLOR][/B]
[QUOTE=Anticanman;15443763]Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"[/QUOTE]
[QUOTE=Luuca;15713642]I pitty anyone who tries to reach into that netting unaware.[/QUOTE]
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline   Reply With Quote
Unread 05-19-2014, 09:37 PM   #3
miceanic
1990 XJ Cherokee
You could get this http://www.dennysdriveshaft.com/p996..._flange_y.html and use the stock ujoint again or this http://www.dennysdriveshaft.com/c139...32_x_3_58.html and use what you have. Either way make sure you measure your bearing caps BEFORE you order and compare them to what's online.
miceanic is offline   Reply With Quote
Unread 05-19-2014, 10:17 PM   #4
19Cherokee96
Would you guys know of any autoparts store i can get them at, i really don't want to order it offline, i figured autozone or somewhere should have them because its off of a 96 ford explorer but the ones they pulled were totally different than what i have
Unread 05-19-2014, 10:32 PM   #5
Agent620
Those u-joints arent going to be strong at all. Get spicer and be done with it. Posting pictures of what you have and measurements would be of great help to finding you the right size.
'99 TJ (DD)
'89 XJ (WIP)
Unread 05-20-2014, 10:49 AM   #6
19Cherokee96
I tried to upload the pictures but it says the size is to big. It does say Spicer C2-26-309 on the drive shaft if that helps, i wont be able to take measurements until i pull it back off.
Unread 05-20-2014, 10:59 AM   #7
19Cherokee96
Here's a few
Unread 05-20-2014, 12:22 PM   #8
Agent620
When you asked for a u joint did you ask for a front or rear joint for the ford?
Looks like a 1310 u joint.
'99 TJ (DD)
'89 XJ (WIP)
Unread 05-20-2014, 12:55 PM   #9
19Cherokee96
we pulled u joints from the front and rear from all models of fords even the aerostar vans nothing matched up, everyone we pulled up where the same length cap to cap on all sides, mine is longer on one side than the other like a lower case t rather than a + sign if that makes sense,
Unread 05-20-2014, 01:08 PM   #10
Agent620
Ahhh, you have an adapter joint then. Likely a 1310/1330.
'99 TJ (DD)
'89 XJ (WIP)
Unread 05-20-2014, 01:10 PM   #11
19Cherokee96
can i get it at an autoparts store? or would i have to order it offline? i would rather go somewhere and buy it instead of ordering one
Unread 05-20-2014, 01:50 PM   #12
Agent620
You'll just have to go through every u joint box the store has IF they even have one. Take the joint to the store and match it up. There might be a part # on your joint in use.
'99 TJ (DD)
'89 XJ (WIP)
Unread 05-20-2014, 04:19 PM   #13
miceanic
1990 XJ Cherokee
http://shop.advanceautoparts.com/p/n...0-p#fragment-2
Says 1330/1310 which is what you need, make sure you measure it at the store first. I've never seen an 8.8 with that flange on it before. Do you know what it came out of? All the ones I've seen have the flat one like at the one at your transfer case.
Unread 05-20-2014, 04:28 PM   #14
19Cherokee96
i was told it came off of a 96 ford explorer, i will try that u-joint from advance tomorrow, hopefully its the right one
Unread 05-20-2014, 04:32 PM   #15
Anticanman
Follow me
The explorers came with a flange yoke and not a ujoint yoke. That's some custom apparatus.
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote
