8.25 trac lock install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 8.25 trac lock install
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 03-22-2008, 01:49 PM   #1
toyotaownsyou
8.25 trac lock install?
just wondering if i were to install a new trac-lock assembly into my 29 spline 8.25 using the factory 3.55 gears, would the gears have to be set-up and spec'd out again or would it be ok to just throw it in there and go?
98 classic - RE 3.5 w/ full pack - 32 BFG ATs - C4x4 tow hooks - stock d30 8.25
toyotaownsyou is offline   Reply With Quote
Unread 03-22-2008, 02:08 PM   #2
sprintagogo
As far as I know they can be fitted without removing the carrier so it doesn't mess with the mesh of the pinion and crown gear.
Theres a write up here - http://www.angelfire.com/oh5/cpa5oh/cpa5ohtech018.htm
Also read this for a few pointers on rebuilding in-situ - http://www.moddedmustangs.com/forums...build-how.html
I am about to do a rebuild of the trac-loc in my Dana 35 so I should know better soon!
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline   Reply With Quote
Unread 03-22-2008, 03:12 PM   #3
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Rebuild the limited slip you already have in the the axle, or install an new limited slip carrier to replace your open differential ?
A rebuild just replaces the the worn limited slip clutches in the differential and it goes back in. Installing any new differential requires that the gears be properly set-up.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 03-23-2008, 07:41 PM   #4
toyotaownsyou
what i was looking at was a complete new assembly with carrier and all to replace my open differential.....
Unread 03-24-2008, 09:12 AM   #5
CJ7-Tim
CJ7-Tim's Avatar
