8.25 Strength - JeepForum.com
post #1 of 18 Old 04-10-2009, 04:59 PM Thread Starter
joec89
8.25 Strength
Alright, so everytime i search the max tire size a 29 spline Chrysler 8.25 with a locker can support i always get mixed answers. My question is can the axle handle 35's and a locker with chromoly shafts? Have any of you tried this?
Thanks in adavance
joec89 is offline
post #2 of 18 Old 04-10-2009, 05:07 PM
jd4x426
i think as long as you dont wheel really hard theyl be ok if you wheel it realy hard you might run into problems
jd4x426 is offline
post #3 of 18 Old 04-10-2009, 05:39 PM
mucovich
1997 XJ Cherokee
i've heard a 29 spline 8.25 is almost as strong as a 44 and mix in chromoly shafts i think 35's will be no problem. Plus i have read a million times from 8.25 owners who have never had a problem with their 29 spline no matter tire size or locker they are running.
97 XJ, 4.0L AW4 NP231, 5" RE franken lift w/ACOS, 35" BFG muds on black steel, chromolied HP ARB 30 - ARB cryco 8 1/4-4.56's w/OBA and RE SYE and custom shaft, Warn M6000 and armour, K&N cold air kit Gibson/Flowmaster for that rockin sound and most importantly a clinometer!
Tow Rig - 2006 2500 cummins RAM
mucovich is offline
post #4 of 18 Old 04-10-2009, 05:51 PM
Prosonic
Prosonic's Avatar
With chromoly shafts? Most definately. I wouldn't hesitate to run that setup. In fact, I'll be going to 33's and a powertrax no slip here real soon, and I'll be running stock shafts.
Mayhem in potentia
Prosonic is offline
post #5 of 18 Old 04-10-2009, 06:10 PM
RockRodHooligan
RockRodHooligan's Avatar
EricsXJ is running a LP30/8.25 combo on his XJ with 35's/shafts/ARBs and apparently has no issues with it.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #6 of 18 Old 04-10-2009, 06:30 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would run that combo also without any worries. If you do break the axle the best solution is a ford 8.8 out of an explorer, but I think unless you are hard on it the 8.25 will get the job done. I run 32's on the 27 splined 8.25 without issues and have been pretty hard on it.
xjfever is offline
post #7 of 18 Old 04-10-2009, 08:07 PM
vtine523
1992 XJ Cherokee
Ive got 34's on stock 29 spline and its been fine. i dont have a locker though i would think that a locker might be the only thing that would "break down" the 8.25
** http://southsidejeepers.freeforums.org/ ** http://southsidejeepers.wetpaint.com/ **
vtine523 is offline
post #8 of 18 Old 04-10-2009, 08:36 PM
1996BlackXJ
I have a friend that runs his 29 spline 8.25 with 35s and a locker with no problems, and he BEATS ON IT! Not sure if he has upgraded shafts or not, my memory says no, but with chromoly's you will be fine.
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #9 of 18 Old 04-10-2009, 09:03 PM
Magus2727
1995 XJ Cherokee
Chromoly's are cheap for the 8.25 also... I would get them the same time as doing gears...
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline
post #10 of 18 Old 04-10-2009, 11:38 PM
EricsXJ
The Post man
EricsXJ's Avatar
Technically its a HP30/8.25 combo, but yeah.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #11 of 18 Old 04-11-2009, 05:42 AM
TTsupra911
with that setup not an issue personally that's the setup I plan on running in the future.
98 Jeep Cherokee XJ -
TTsupra911 is offline
post #12 of 18 Old 04-11-2009, 06:38 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I wouldn't hesitate to run that setup, but I would use the C-clips as an excuse to do a rear disc swap.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #13 of 18 Old 04-11-2009, 07:04 AM
woodie416
2011 JK Wrangler
sorry to hijack the thread but how does one go about checking to see if they have a lp/hp dana 30 and 27 or 29 spline 8.25?
2011 JKUR 6 speed.
The Weekend Warrior
woodie416 is offline
post #14 of 18 Old 04-11-2009, 07:33 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You have a High Pinion D30 and you may have a 29 spline 8.25 if the build was late enough. Only way to know is to pull an axle shaft and count the splines.
That or try to find a BOM (Born On Manufacturer) date and see if the dealership will run the Vin or that BOM and see if it is a 29 spline unit.
93 Sport
Specs in Profile.
balloo93 is offline
post #15 of 18 Old 04-11-2009, 02:40 PM Thread Starter
joec89
thanks for the help everyone I will be getting 35s when my tires wear out
joec89 is offline
97+ E fan strength xjman4life XJ Cherokee Technical Forum 3 08-01-2008 08:34 PM
1997 8.25 strength ? newbs XJ Cherokee Technical Forum 15 05-13-2008 09:54 PM
D35 Strength Testimony keeth1123 XJ Cherokee Technical Forum 7 02-26-2008 11:02 AM
Strength of a D35? Meatroach XJ Cherokee Technical Forum 25 07-31-2006 05:26 PM
ax5 strength? slayer2000 XJ Cherokee Technical Forum 5 04-18-2004 12:47 PM
