Is this an 8.25 rear end? - JeepForum.com
post #1 of 10 Old 10-16-2013, 08:58 PM Thread Starter
sammy12oz
I purchased a rear end tonight. I was told it was a 97+ 8.25.
After getting it home I check the tags. One is stamped 35 and the other 2546.
I'm assuming this is in fact a Dana 35 with that tag.
The Axle tube is 3", I read in a thread here that the 35 are 2 3/4" while the 8.25 are 3".
I'm not sure and was hoping someone here could help me out.
I paid 100 for it.
Thanks
sammy12oz is offline
post #2 of 10 Old 10-16-2013, 09:03 PM
sjones26573
That's an 8.25
EDIT:
For your future reference:
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 10 Old 10-16-2013, 09:20 PM Thread Starter
sammy12oz
Thanks for the quick response. That puts a smile on my face. It turns out that my 2000 already has the 8.25 rear. Maybe I'll take it apart and get a better understanding of how these things work. I also got the drive shaft with it so at lease I have a spare now.
post #4 of 10 Old 10-17-2013, 06:23 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
http://www.howstuffworks.com/differential.htm
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 10 Old 10-17-2013, 07:20 PM
miceanic
1990 XJ Cherokee
Sounds like you might want to read up some on axles. You did not realize you had the same axle already so I have to assume you did not check to make sure it was the same gear ratio. More than likely it is 3.55 but some XJ's also came with 3.05, 3.55, 3.73 and 4.10, it is important that both front and rear match or your transfer case will grenade itself. You could also use one of the shafts out of that axle as a spare. I believe they are the same length, I would double check as I have a Dana 35 still.
miceanic is offline
post #6 of 10 Old 10-17-2013, 09:13 PM
um7267
the housing is flat on the bottom of the c8.25 that is the easiest way to id them
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #7 of 10 Old 10-19-2013, 01:27 PM
stephenfarris
And that rubber stock fill plug are two dead give-a-ways
stephenfarris is offline
post #8 of 10 Old 10-19-2013, 01:34 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by stephenfarris View Post
And that rubber stock fill plug ....
Later Dana 35's also use the exact same plastic diff cover plug.
The best way to identify an axle housing, is by the shape of the housing itself and the size/shape of the diff cover. See picture above.
CJ7-Tim is offline
post #9 of 10 Old 10-19-2013, 09:22 PM Thread Starter
sammy12oz
Agreed, I mistakenly assumed the piece of metal stamped with "35" meant it was a dana 35.
post #10 of 10 Old 10-20-2013, 03:19 PM
um7267
unless the plug is the original it will say C8.25 or DANA35
um7267 is offline
