8.25 carrier Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 8.25 carrier Question
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 04-06-2015, 08:54 PM   #1
MFswamper
I drive a 1991 jeep Cherokee limited 4.0l. Ive been told I could put my 8.25 carrier inside my dana 35 axel with the originall U-joints. Is this true? Can I use the same Axel shafts? I believe the carrier is out of a 1992 dodge Dakota 4x4. PLEASE HELP!!!
MFswamper is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 10:48 PM   #2
AZ Jeff
2014 JK Wrangler
No, a carrier for a Chrysler 8.25 inch "corporate" axle will NOT fit in a Dana 35 housing. If you want to replace your carrier, the easiest/cheapest way is to get an entire axle assembly from another XJ. Be sure to match your existing ratio if your XJ has 4wd.
AZ-Jeff
WANTED--MJ Comanche to restore. Must be solid, (relatively) rust free chassis. Send me a PM if you have a line on one that is for sale.
AZ Jeff is offline   Reply With Quote Quick reply to this message
axel , chrysler 8.25 , dana 35 , xj
