62mm Throttle Body - Page 2 - JeepForum.com
post #16 of 26 Old 04-20-2017, 10:39 AM
RedJeepster1
Low and Slow
RedJeepster1's Avatar
Originally Posted by delesandwich View Post
Running a new quadratec head, banks torque tubes and 784 injectors on my 01 Cherokee would you guys recommend a larger TB and realistically what kind of improvement would I get?
Sent from my SAMSUNG-SM-G891A using Tapatalk
New quadratec head?
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 XJ w/ 350k+, AW4, NP231, Locked Rear, HD Crown Leafs, trimmed to fit 33's
RedJeepster1 is offline
post #17 of 26 Old 04-20-2017, 11:05 AM
delesandwich
Originally Posted by RedJeepster1 View Post
New quadratec head?
Sorry, the Promaxx head from quadratech
delesandwich is online now
post #18 of 26 Old 04-20-2017, 11:16 AM
RedJeepster1
Low and Slow
Which I assume is just a new casting of a factory head? If you have a better flowing exhaust, and bigger throttle body, and higher output injectors, you should in theory be able to flow more and and fuel through the engine and gain some HP. There's never any guarantee of that though. I certainly wouldn't expect any fuel economy increases. Whats your goal with the bigger throttle body? Just more power? Is the Jeep otherwise stock?
post #19 of 26 Old 04-20-2017, 11:23 AM
delesandwich
Promaxx claims a heavier than stock casting and hardened valve seats. I originally had the 0331 boat anchor that cracked on me. Now I'm trying to squeeze as much power out of it while still keeping it reliable. It's about to make a trip from South Texas to Alaska
post #20 of 26 Old 04-20-2017, 11:35 AM
RedJeepster1
Low and Slow
Have you regeared for those tires? That will make a big difference in how the Jeep drives. Btw, love the wheels. I have a set myself although I'm not currently running them.
post #21 of 26 Old 04-20-2017, 11:37 AM
delesandwich
Gears and lockers are on the list for sure, don't really have the time to install them right now though
post #22 of 26 Old 04-20-2017, 11:49 AM
RedJeepster1
Low and Slow
I think that would be your biggest gain. Most of the bolt on's don't do a whole lot for the 4.0. At last in my experience.
post #23 of 26 Old 04-20-2017, 12:00 PM
delesandwich
Been kind of holding out hoping to find a set of rubicon 44's
post #24 of 26 Old 04-21-2017, 11:53 AM
bluejunior
bluejunior's Avatar
I'm with red on this one. Proper gearing will do a lot more for the butt dyno than the throttle body, though it should help some in theory. A lot of people claim big noticeable improvements but personally I think it's usually an illusion caused by the bigger TB being more open at a given pedal position.
Also...do you mean TJ 44's? It's worth noting they get the 44 diff, but the outers are identical to a d30. Most people break shafts or u-joints anyway so that upgrade may do nothing but cost you under diff ground clearance.
Lifted, Locked, Stiffened
bluejunior is offline
post #25 of 26 Old 04-22-2017, 09:33 AM
delesandwich
Didn't really consider the outers were D30 on the tj 44's. The appeal of the turn key 44's with lockers and 4.10's got to me. I have no plans to go with bigger tires and still want decent highway drivability.
post #26 of 26 Old 04-22-2017, 09:54 AM
bluejunior
bluejunior's Avatar
If it works for you, it works for you. Just wanted to make sure you knew what you were getting.
60mm or 62mm throttle body??? GangstaFun XJ Cherokee Technical Forum 10 03-26-2013 02:01 PM
62mm throttle body XJ636 XJ Cherokee Technical Forum 28 12-09-2012 01:32 PM
62mm throttle body for a RENIX (non-HO) motor? my900ss XJ Cherokee Technical Forum 5 06-18-2007 09:03 AM
62mm Throttle body sjns XJ Cherokee Technical Forum 4 02-06-2004 06:53 AM
62mm Throttle Body Bblock XJ Cherokee Technical Forum 5 09-04-2002 11:42 AM
