62mm Throttle Body - JeepForum.com
post #1 of 26 Old 05-03-2009, 05:11 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
62mm Throttle Body
Where can i find a decently priced throttle body? Jeepers and Creeperz website is down. Ive dont alot of research and people like the Rubicon Express one, but i cant find it for sale any more.
Im a little hesitant to buy one off ebay. But any other recommendations would be great
-Brendan
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #2 of 26 Old 05-03-2009, 06:22 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Have yours bored at a local machine shop. Unless you have some serious work done to the head, 24lb fuel injectors and a free flow exhaust you don't need a 62MM TB. A 60MM TB will give a noticeable improvement.
CJ7-Tim is offline
post #3 of 26 Old 05-03-2009, 07:14 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
Originally Posted by CJ7-Tim View Post
Have yours bored at a local machine shop. Unless you have some serous work done to the head, 24lb fuel injectors and a free flow exhaust you don't need a 62MM TB. A 60MM TB will give a noticeable improvement.
awesome, thanks tim. ill see what i can find locally
3.6L V6 - Manual
bmyohn is offline
post #4 of 26 Old 05-03-2009, 07:56 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
i just found this one on ebay....its a 63mm throttle body. seems like a pretty good deal.
its 160, no core charge, but you do get 50 bucks back if you send them the old throttle body back..
what do you guys think?
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
3.6L V6 - Manual
bmyohn is offline
post #5 of 26 Old 05-03-2009, 08:06 PM
tock172
Strokedjeep.com
I got a 63mm TB and it was perfect, very fast and refunded my core charge quickly.
'99 Techno Violet M3 | '05 Audi S4 quattro 6MT | '04 BMW 330i | '86 BMW 535i | '96 Jeep Cherokee
tock172 is offline
post #6 of 26 Old 05-03-2009, 08:07 PM
jeeptorino68
1992 XJ Cherokee
do you have a drill press? if soyou can do a 60mm your self for the cost of a sanding drum, its really really easy, and like they said if you have just an aftermarket muffler, and maybe a free flow intake, then the 60mm will be fine, if more mods, like greater engine mods then you will want 62mm or bigger
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #7 of 26 Old 05-03-2009, 08:49 PM
diskman_1
1992 XJ Cherokee
Yup. I did mine on my cheapo tabletop drill press and a $4.00 rubber drum and a $5 pack of drum sandpaper refills. I removed the IAC, butterfly and TPS. Used a marker to mark the butterfly area and went no further than that. Took about 15-20 minutes to do it and polish with 2000 grit paper when done.
diskman_1 is offline
post #8 of 26 Old 05-03-2009, 08:53 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
im planning on a golen 4.6L stroker and he recommends a 62mm TB and a header. so im looking at a banks header and a 62-63mm TB. he says that could get into the 285 - 300 HP range on his stroker
3.6L V6 - Manual
bmyohn is offline
post #9 of 26 Old 05-03-2009, 08:54 PM
01ClassicXJ
i might have to pick one up myself.
01ClassicXJ is offline
post #10 of 26 Old 05-03-2009, 09:21 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
i went ahead a purchased one. we will see how it goes.
3.6L V6 - Manual
bmyohn is offline
post #11 of 26 Old 05-28-2009, 09:59 PM
Bounty Hunter
I have a few 62mm TB's available, professionally machined and cheaper than what you pay on Ebay. Shoot me an email at bountyhunter AT sija.org if you're interested.
'95 YJ 2.5L
Bounty Hunter is offline
post #12 of 26 Old 05-29-2009, 01:23 AM
nrpalmer32
1987 XJ Cherokee
X2 on StrokedJeep.com. I have the 60mm for my Renix and it was great, no probs and same experience as tock172. If you just have yours bored out you either need to purchase/fab another butterfly, or only bore the the before and aft of the butterfly. Which to me seems like you'd have a bottleneck, which is what you are trying to get rid of in the first place. When you get the TB from him, it is bored straight through and comes with the larger butterfly, and I can't say enough about his customer service level! The TB from StrokedJeep.com for ur year come in 62mm, 62.5mm, 63mm and 64mm. He also has other parts for stroked engines, hence the name.
nrpalmer32 is offline
post #13 of 26 Old 05-29-2009, 02:52 AM
kongpheng
has anyone noticed Shift Changes on an automatic when a new TB is installed and the ECU has been RESET?
I have, it feels good. i like my 62mm.
is this normal?
2001 Cherokee XJ Sport 4.0L
3" Rough Country Lift w/ Daystar 1.25" TC Drop Kit
Flowmaster Delta 40 Series
K&N Drop in Air Filter & Procomp 10" E-Fan
AirRaid TB spacer w/ 62mm Bored TB
BFG All-Terrain K.O. on Black ProComp 87's
kongpheng is offline
post #14 of 26 Old 04-20-2017, 08:06 AM
delesandwich
Running a new quadratec head, banks torque tubes and 784 injectors on my 01 Cherokee would you guys recommend a larger TB and realistically what kind of improvement would I get?
Sent from my SAMSUNG-SM-G891A using Tapatalk
delesandwich is online now
post #15 of 26 Old 04-20-2017, 08:15 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
None.
TheBoogieman is offline
60mm or 62mm throttle body??? GangstaFun XJ Cherokee Technical Forum 10 03-26-2013 02:01 PM
62mm throttle body XJ636 XJ Cherokee Technical Forum 28 12-09-2012 01:32 PM
62mm throttle body for a RENIX (non-HO) motor? my900ss XJ Cherokee Technical Forum 5 06-18-2007 09:03 AM
62mm Throttle body sjns XJ Cherokee Technical Forum 4 02-06-2004 06:53 AM
62mm Throttle Body Bblock XJ Cherokee Technical Forum 5 09-04-2002 11:42 AM
