600 Dollars budget for lift kit - What to get? - Page 2 - JeepForum.com
post #16 of 18 Old 02-19-2013, 11:55 AM Thread Starter
gutiaqp
1997 XJ Cherokee
So after reading more than 1 month, searching everywhere english/spanish Jeep, Xj off road forums
Finally make my mind and order a Zone Offroad 4.5
I know it will involve more budget at the end but that way i will not have to say to me why i did not get the 4.5" instead the 3"
I will create a post for the build, i will continue PB blasting and star replacing the freaking bolt from the rear shock 2 of them a re gone, so now i have to fish now ones.
Thank you all for your opinions and time for reading my almost good spelled english, lol
Cheers
gutiaqp is offline
post #17 of 18 Old 02-19-2013, 07:34 PM
1CleanTJ
1CleanTJ's Avatar
Cheers
if you have access or know someone with a air chisel, you can pop out the old upper shock mount nuts in a matter of about a minute for all 4
replace with some 5/16" 1 1/4" length bolts.
get a piece of thin wire (mechanics wire etc) , go through the shock mount hole first, then bring it out the center of the crossmember, wrap the wire around the threads of new bolt with bolt head pointing towards the ground. pull wire so it goes back towards shock mount hole. bolt goes right into hole easiest way to do it for sure.
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #18 of 18 Old 02-19-2013, 09:17 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
with your budget I would look into piecing together a kit, 90% of the time you can build your own lift with quality components cheaper then buying the pre packaged kit.
RE superride is right in your price range, Zone makes decent stuff, I would avoid Rusty's I've personally had bad issues with rustys products on 2 different Jeeps .
I am not fond of RC springs either
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
lift kit advice , pro comp lift kit , rough country
