60 amp fuses keep blowing after battery rewire - JeepForum.com
post #1 of 7 Old 10-01-2012, 06:58 AM Thread Starter
zimsy
1993 XJ Cherokee
So, I keep blowing fuses to my alt power 2 every time I try to turn my xj over. I've got new battery cables and terminals and all my lights work but it won't start. I keep reading I should check my grounds and wiring but I'm not sure where to check. The volt meter says my battery still has a full charge. So can anyone out there help me out and tell me why I've done wrong? I've got my 2 wires off my starter going to the positive and one coming off the "power block?" right in front off the right side engine mount. My negative is going to the fusing house. It's just one cable. Btw I have ac delete. Any info would be handy. Thanks!!!!
zimsy is offline
post #2 of 7 Old 10-01-2012, 09:06 AM
buildin1XJ
If this happened right after you did the rewire and you are now blowing fuses I would look for a wire hooked up in the wrong place or a grounded positive.
buildin1XJ is offline
post #3 of 7 Old 10-01-2012, 09:17 AM Thread Starter
zimsy
1993 XJ Cherokee
Okay. Cool. Going back to napa today to waste more money on fuses. Then check my voltage off of the starter and grounds.
zimsy is offline
post #4 of 7 Old 10-01-2012, 09:58 AM
GetLifted
Sounds like you have the wires reversed?
GetLifted is offline
post #5 of 7 Old 10-01-2012, 11:22 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Basic troubleshooting principle - "What changed last?"
You said you just replaced your main battery wiring, so start looking there. Make sure you don't have something in the wrong place, or something touching something it should not.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #6 of 7 Old 10-01-2012, 01:41 PM Thread Starter
zimsy
1993 XJ Cherokee
Wow, I'm an idiot. I had the negative terminal wire going to the fuse box. Looked up some images using the all mighty google machine and found out I was wrong. Made a jumper wire for the 60 amp alt fuse.(I know not smart!) had a buddy come look at it and he said (after changing wires around) that it looks to be set up right. I apparently had both wires coming off the starter to the positive terminal. I then took the smaller of the two (I perceived the smaller wire to be the ground???) then grounded it out. Next I reconnect the negative battery cable on and got a spark. (Not good?) can anyone tell me what the heck I'm doing wrong here? I'm not the sharpest tool in the shop but I've got the determination to get this thing running again.
zimsy is offline
post #7 of 7 Old 10-01-2012, 01:43 PM Thread Starter
zimsy
1993 XJ Cherokee
And that power block on the engine isn't for power I take it. I think it's a ground. So I grounded everything to the body below the fuse box.
zimsy is offline
battery , battery connection , fuses , starting issue , wiring
Blowing fuses 97whitexj XJ Cherokee Technical Forum 2 08-05-2011 07:05 PM
Blowing fuses? anderson5290 XJ Cherokee Technical Forum 7 01-19-2011 04:32 PM
always blowing fuses in 99 xj please help weegie22 XJ Cherokee Technical Forum 3 06-02-2009 09:30 AM
Blowing fuses... blastsmith MJ Comanche Technical Forum 8 10-05-2007 01:31 PM
Blowing fuses.....why? PRYDE XJ Cherokee Technical Forum 3 07-14-2005 11:33 AM
