-   -   60 amp fuses keep blowing after battery rewire (http://www.jeepforum.com/forum/f11/60-amp-fuses-keep-blowing-after-battery-rewire-1422886/)
zimsy 10-01-2012 06:58 AM
So, I keep blowing fuses to my alt power 2 every time I try to turn my xj over. I've got new battery cables and terminals and all my lights work but it won't start. I keep reading I should check my grounds and wiring but I'm not sure where to check. The volt meter says my battery still has a full charge. So can anyone out there help me out and tell me why I've done wrong? I've got my 2 wires off my starter going to the positive and one coming off the "power block?" right in front off the right side engine mount. My negative is going to the fusing house. It's just one cable. Btw I have ac delete. Any info would be handy. Thanks!!!!
buildin1XJ 10-01-2012 09:06 AM
If this happened right after you did the rewire and you are now blowing fuses I would look for a wire hooked up in the wrong place or a grounded positive.
zimsy 10-01-2012 09:17 AM
Okay. Cool. Going back to napa today to waste more money on fuses. Then check my voltage off of the starter and grounds.
GetLifted 10-01-2012 09:58 AM
Sounds like you have the wires reversed?
5-90 10-01-2012 11:22 AM
Basic troubleshooting principle - "What changed last?"
You said you just replaced your main battery wiring, so start looking there. Make sure you don't have something in the wrong place, or something touching something it should not.
zimsy 10-01-2012 01:41 PM
Wow, I'm an idiot. I had the negative terminal wire going to the fuse box. Looked up some images using the all mighty google machine and found out I was wrong. Made a jumper wire for the 60 amp alt fuse.(I know not smart!) had a buddy come look at it and he said (after changing wires around) that it looks to be set up right. I apparently had both wires coming off the starter to the positive terminal. I then took the smaller of the two (I perceived the smaller wire to be the ground???) then grounded it out. Next I reconnect the negative battery cable on and got a spark. (Not good?) can anyone tell me what the heck I'm doing wrong here? I'm not the sharpest tool in the shop but I've got the determination to get this thing running again.
zimsy 10-01-2012 01:43 PM
And that power block on the engine isn't for power I take it. I think it's a ground. So I grounded everything to the body below the fuse box.
The time now is 10:58 PM.
