Quantcast $6 Shocks at Summitracing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > $6 Shocks at Summitracing
Old 03-18-2009, 10:26 PM   #1
chainerx
1997 XJ Cherokee
http://store.summitracing.com/egnsearch.asp?Ns=P_SRE_DisplayPrice|0&N=700+429492 5130+4294919396+400065+115&Ntt=&Ntk=&rsview=sku&RC =10#rstop
Not intended for Jeeps, but if the length is right for your rig it's a hell of a deal.
1997 Jeep Cherokee
chainerx is offline   Reply With Quote
Old 03-18-2009, 11:02 PM   #2
BayouBengal85
thats insane. btw, does anyone know what size shock id need for 96 xj sport 2wd with a 2" budget boost?
96 2wd XJ Sport, 4dr, 4.0HO, Auto, 3.55 gears,107k Miles
15x8 Canyon Rims
31x10.50x15 Futura Adventurer H/T's
Fram Air Hog Filter
Magnaflow Hi Flow Catalytic Converter
Dynomax Superturbo Catback Exhaust
BayouBengal85 is offline   Reply With Quote
Old 03-18-2009, 11:20 PM   #3
scherf68
Thanks for the link, twin tubes aren't the best but I got a pair for my TJ.
97 mean green tj, 4.0, auto, AA SYE, rubicon 3.5 superflex, dana 44 front and rear, air lockers, 4.10 gears, jks quick discos, 35 nitto grappler, more 1 in mml/bl, swing away tire carrier, Warn x8000i winch and plate, tube fenders by zesty fab, jks tie rod and sway disco's, custom roll cage.
scherf68 is offline   Reply With Quote
Old 03-19-2009, 12:56 AM   #4
XJoutlaw
1989 XJ Cherokee
which ones are suppose to fit
XJoutlaw is offline   Reply With Quote
Old 03-19-2009, 05:15 AM   #5
chainerx
1997 XJ Cherokee
None. They are intended for other vehicles, you'll need to know what your compressed and extended lengths are for shocks and figure out if any of those will work.
1997 Jeep Cherokee
Old 03-19-2009, 07:33 AM   #6
91xjgawes
Brand/Model # Extended Collasped Travel Position
Monroe 32252 (* Stock) 21.25 13 8.1 Front
Monroe 37193 (* 1-3 “ Lift) 24.25 13.37 10.8 Front
Monroe 911524 (* UpCountry) 21.00 13.4 7.6 Front
Doetsch DT3350 ( 3-5” Lift) 26.5 15.5 11.0 Front
ES1000 ES124515 (* 3" Lift) 24.50 14.38 10.0 Front
ES1000 ES121515 (* 0-2" Lift) 21.52 12.72 8.8 Front
ES3000 ES324515 (* 3" Lift) 24.70 14.52 10.2 Front
ES3000 ES321515 (* 0-2" Lift) 20.24 12.45 7.8 Front
ES9000 ES921515 (* 0-2" Lift) 21.75 13.06 8.6 Front
ES9000 ES924515 (* 3" Lift) 24.70 14.52 10.2 Front
Skyjacker SJA-H7016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Skyjacker SJA-H7025 (* 3-5" Lift) 24.75 14.54 10.2 Front
Skyjacker SJA-N8016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Skyjacker SJA-N8025 (* 3-5" Lift) 24.75 14.54 10.2 Front
Skyjacker SJA-M9016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Rancho RS5239 (* 3" Lift) 23.75 14.37 9.38 Front
Rancho RS5128 (* Stock) 20.87 13.00 7.8 Front
Rancho RS99239 (* 3" Lift) 23.75 14.37 9.38 Front
Rancho RS99128 (* Stock) 20.87 13.00 7.8 Front
Rancho RSX17317 (* 3" Lift) 23.75 14.50 9.25 Front
Rancho RSX13036 (* Stock) 20.50 12.87 7.6 Front
Bilstein F4-B46-1798 (Stock+Upcountry) 21.50 13.25 8.25 Front
Bilstein F4-BE5-6241-H8 (4” Lift)……………………………………….………….Front
Monroe 32269 (* Stock) 21.50 13.37 8.1 Rear
Monroe 37194 (* Upcountry) 21.12 13.87 7.2 Rear
Monroe 911525 (* Upcountry) 21.50 13.87 7.2 Rear
Monroe 37029 (1-3” Lift ) 23.00 14.375 8.6 Rear
Superlift SLF-85112 (* 2-4" Lift) 24.00 14.50 10 Rear
Superlift SLF-84140 (* 3-5" Lift) 26.07 15.57 10.5 Rear
Superlift SLF-85080 (* 0-2" Lift) 21.57 13.32 8.25 Rear
ES1000 ES124509 (* 3" Lift) 24.86 14.84 10 Rear
ES1000 ES121515 (* 0-2" Lift) 21.52 12.97 8.5 Rear
ES3000 ES324509 (* 3" Lift) 24.84 14.82 10 Rear
ES3000 ES322509 (* 0-2" Lift) 22.58 13.71 8.8 Rear
ES9000 ES922509 (* 0-2" Lift) 22.58 13.72 8.8 Rear
ES9000 ES924509 (* 3" Lift) 24.84 14.82 10 Rear
Skyjacker SJA-N8058 (* 3-5" Lift) 24.84 14.82 10 Rear
Skyjacker SKA-H7058 (* 3-5" Lift) 24.84 14.82 10 Rear
DT-3000 DOE-3265 (* 4" Lift) 24.50 14.50 10 Rear
DT-3000 DOE-3268 (* 2" Lift) 24.50 14.50 10 Rear
DT-8000 DOE-8265 (* 4" Lift) 24.50 14.50 10 Rear
Rancho RS5194 (* 2-3" Lift) 23.25 14.37 8.8 Rear
Rancho RS5259 (* Stock) 21.50 13.50 8 Rear
Rancho RSX13037 (* 0-2" Lift) 21.12 13.50 7.62 Rear
Bilstien F4-B46-1799 (Stock+UpCountry) 21.50 13.25 8.25 Rear
Bilstein F4-BE5-6686-H6 (4” Lift) …………………………………………….Rear
blue jeep club member 174
2001 xj- 2 inch bb moabs
1998 zj 5.2- 245/75's moabs
91xjgawes is offline   Reply With Quote
Old 03-19-2009, 10:18 AM   #7
XJoutlaw
1989 XJ Cherokee
How do you figure the compressed and extended length you need I have a 89 lardeo thats going to get a 3 inch lift soon?
Old 03-19-2009, 10:20 AM   #8
XJoutlaw
1989 XJ Cherokee
How do you figure what you compressed and travel lengths are and thanks chainerx for telling me.
Old 03-19-2009, 11:56 AM   #9
chainerx
1997 XJ Cherokee
Guy above posted the lengths of shocks for XJ's. So compare the 3" lift shocks numbers to the ones at summit.
1997 Jeep Cherokee
Old 03-19-2009, 12:09 PM   #10
chainerx
1997 XJ Cherokee
These are the numbers for the edelbrocks for $6.
Part # Extended (in)Compressed (in)Stroke (in)Upper Mount Lower Mount Reservoir Diameter
20148 - 19.01 - 12.50 - 6.51 - ES126 - ES128 - 50
20121 - 19.62 - 12.50 - 7.12 - BP18 - ES24 - 60
20162 - 28.09 - 16.47 - 11.62 - S10 - ES83 - 60
Source: http://www.nagca.com/grandtech/elelbrockshocks.htm
Depending on your lift size or if you swap in your old bar pins or get bpe's they could be made to work.
20162 is for Ford, F-150 1980-96, 4WD, Rear, 4 in. Lift rear
20121 is for Jeep Wrangler, 1997-2002, 4WD, Rear, With 4 in. Lift rear
20148 id for GM Full-Size Trucks, 1988-1998, 4WD, 4 in. Lift front
1997 Jeep Cherokee
Glock Forum
