#1 | |
$50 for ZJ rear discs
my local junkyard has a few zjs with the rear discs still in them, person there said $25 bucks a side for everything, not bad at all. i was wondering if i can use the ebrake cables the zj uses. also all i really need to do is just pull the shafts and a few bolts right?
( northjerseyjeepclub.org ) 99 cherokee sport auto/231 - RK 3 link long arms, RE 5.5" coils, RC 4.5 leafs w/ RE 1.5" boomerang shackles, RE track bar & bracket, JKS disco's, rustys/RC shocks, P.O.R.C SYE w/ front drive shaft, rugged ridge steering, OR-fab front winch bumper w/ superwinch LP8500, surco roofrack, airflow snorkel, bushwackers & 33" maxxis bighorns . 95 cherokee sport auto np231 - 4.5 RE coils, OME 3 inch full packs, stock track bar ,RE upper and lower control arms, JKS quicker disco's,RC shocks and steering stab.stock tires/rims,t-case from the 99xj, slowly being robbed of all its part before it goes to the JY |
#2 |
It's been a while since I did my conversion, but I "THINK" the ZJ parking brake cables may be too short to work on an XJ.
What I did was to take the parking brake levers from the ZJ, and onto them, weld the end of the levers from the XJ drum parking brake (the one that attaches to the trailing shoe.) That allowed me to connect the XJ cables to the ZJ parking brake levers.
AZ-Jeff 1992 XJ 2" lift -- RIP 2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links. |
#3 |
now as far as taking the brake system off the zj, should be pretty straight forward and easy right?
#4 | |
#5 | |
#6 |
Jim, that's a great price. I just paid $200 for a complete ZJ D44A (disc to disc) and the proportioning valve. I figure once I pilfer the brakes off it, I can sell the leftovers and make a few bucks back on it. It's good if you can take everything apart yourself, so you have an idea of how it goes back together; that's why I bought the whole rear. I can disassemble it when I have the time, clean everything up, and put them on my XJ when I'm ready.
Steve Ragusa - North Jersey '01 XJ - SOLD! '06 Infiniti G35x - New DD. :) '03 KJ Limited -WifesJeep- 3.7, Auto, NP 242, '06 Limited 17's. 40K miles. |
#7 |
im sure the dude will sell me the whole axle for cheap, but i just cant have another axle in the driveway. haha.
#8 |
You will have to ream out the backing plate a touch(very little, a dremal works well). I never did finish the Parking brake, I'll get it done someday
98 XJ Limited Stock XJ tire carrier for sale http://www.jeepforum.com/forum/showthread.php?t=424930 |
#9 |
Vendor
You should be able to just use your stock parking brake cable, loop it around the lever arm on the ZJ brakes, then cable clamp it.
Jason West - Jeepin.com | JeepinOutfitters.com '95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc. '09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp '00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
#10 |
Does this work on 89's?? Theres a wrecked zj at my yard and I'd love to do the conversion.
2001 Sport Silver 170,XXX 100 miles per day DD Rusty's 3 inch 30's PORC SYE 3 Inch Sway Links |
#11 |
Vendor
Yes, it's a little more involved though. You'll need to redrill the backing plate to bolt to your axle housing ends, and you'll need to either make a spacer for the retainer plate on the axle, or get some TJ Rubicon retainer plates and redrill them, but yeah, it'll work.
#12 |
Okay, I understand, where to get tj rubicon retaining plates?
#13 |
Vendor
dealership. they're fairly inexpensive.
#14 |
besides reaming out the backing plate a bit, its all prety simple? is there anything else im going to need to take off the zj?
#15 |
Will these work on a 97 TJ and if so could you pick me up a set set. I'll pay you some labor and shipping via paypal. Can't find that stuff that cheap here in japan. Also is the bolt patern the same as a 97 TJ? Thanks, Kent
97 TJ, 2.5, Auto, 33x9.50/15 on MT's, WARN front and rear bumpers, Best Top tinted top, Pioneer Stereo, 4 4.25" Kenwood speakers, D30HP and D35 with 4.56 gears, 3.5 Skyjacker lift [B]BLACK JEEP CLUB MEMBER #1997[/B] [B]2008 National Topless Day Participant #1[/B] [******][/******] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
