Quantcast 5.O mustang motor in a jeep? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 5.O mustang motor in a jeep?
Old 06-11-2006, 05:17 PM   #1
88JeepLimited
well i have an 88 jeep limited with a straight six in it. what i was wondering was is there any possible way a 5.0 302 out of an 89 mustang fit in it. the jeep has over 300,000 miles on it and is about to give out soon, i think is would be sweet to have that motor in it. would it work? what would all have to be replaced thanks...
88JeepLimited is offline   Reply With Quote
Old 06-11-2006, 05:26 PM   #2
XJ4oh
1997 XJ Cherokee
People have done a 350 swap in XJ's before, so a 302 would definatly fit.
But, Im very sure that you also have to swap the transmission, which also means getting adaptors for the transfer case if its 4wd, and probaly a new correct length driveshaft as well. I could be wrong, someone may sell adaptors but Im not sure.
'97 XJ... 4.0 4x4 AW4.
2" budget boost w/t-case drop.
30x9.5 Kumho M/T's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
XJ4oh is offline   Reply With Quote
Old 06-11-2006, 08:42 PM   #3
xj#2
not too hard
if you wanna run a ford engine get for tcase and tranny....easy enough.
if its electronic the get the electronics with it
88 mj 4.0 5 speed 4x2
87 wagoneer 4.0 aw4 4x4
95 cherokee classic for parts 4x2
xj#2 is offline   Reply With Quote
Old 06-11-2006, 08:53 PM   #4
mpd8488
Check out https://eshop.advanceadapters.com/
They may have the stuff you need to keep your current t-case and maybe even tranny
1997 XJ Sport 4 door
4.0, AX15, NP231
Stock- no $
mpd8488 is offline   Reply With Quote
Old 06-11-2006, 10:23 PM   #5
Bgeddes
Ridin' with the King
If the entire setup has 300K miles on it, the V-8 won't be the best thing for them. However, mounting replacements along with the new engine might be easier than an enitre new drivetrain.
'05 KJ CRD and '00 XJ Classic > Stock DDs
'88 YJ Sahara > Weberized, HEI, Shackle Lift, Herculiner, more on the way
Bgeddes is offline   Reply With Quote
Old 06-12-2006, 10:10 AM   #6
David K.
I think that you could get a 5-600$$ engine from a junk yard, if it is the same age meaning pre HO you should be able to get it in and running in no time. CHEAP too!!. with a new fuel pump you might even get a pre 96 engine.
I think you will need
Radiator
drive shafts
motor mounts
tranny
tcase adaptor
Computer b/c it is prolly tbi
Fuel pump should work if same psi is required. Hope that you can have a hydrolic shop mate your new power steering pump to your steering box.
A stroker would even work better if you want the power. don't forget emmisions
David K. is offline   Reply With Quote
Old 06-12-2006, 01:35 PM   #7
Buntaluffigus
What about all of that smog junk?
Edit: I assume that it's a daily driver.
Buntaluffigus is offline   Reply With Quote
Glock Forum
