#1 | |
5 inch lift questions
if i were to install a 5 inch custom lift what other parts would i need to replace that are critical? im talking LCAs or a longer driveshaft or what? all help would be nice....
#2 | |
- T-Case Lowering Kit XJ/ZJ - Brake Line SS Rear XJ/ZJ - 3" Front Bumpstop - Shackle XJ Rear 1.25" Lift - U-Bolts YJ Dana 35 Rear - BRAKE LINES SS FT XJ/MJ/ZJ/C - Control Arm SF2 Lower Fixed - Control Arm SR2 Upper Ft Fix - Sway bar Disconnects Set With 6" Centers Tube - Sway Bar Disconnects Adapter Bracket XJ-ZJ - Sway Bar Relocation Brackets - Extra H.D. Track Bar XJ/ZJ - H.D. Track Bar Bracket XJ/ZJ - Coil Springs ZJ 4.5" Front - 4.5" Extreme Duty XJ Rear Spring - XJ Control Arm Drop Brackets Anyone else want to chime in and add to, please do...I might be missing something, but this list is off the Rubicon Express website and it's for a 5 1/2 inch lift. Good luck!!
89 Jeep Cherokee Laredo 4x4 - 3" Rough Country BB AAL/Coil - ProComp Shocks - 31x11.50 Super Swamper LTB's - 15" Rock Crawler 51 series rims (black) - Homemade front Brush guard Waiting to be installed: - 95 Dodge Dakota rear leaf springs (1 1/2" lift) - ACOS upfront adjusted to equal 4 1/2 inches - RE Stainless steel brakelines - 4 degree shims - 1" Rockratz Transfer Case Drop |
#3 |
Little Red Menace
Depending on the year, a TC drop more than likely will not stop the vibes at the DS. I would STRONGLY suggest a SYE and CV-DS for a 5" lift.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#4 |
id also suggest to upgrade to adj. upper and lower instead of fixed LCA"s and some drop brackets/braces. just my .02
2001 2-door XJ prerunner 6.5" RE 33x10.5" BFG A/T KO 15x8" rockcrawlers w/3.75" bs hannemann 6" bulge flat top fiberglass fenders bilstein 11" travel 5150's RE XD trackbar / frame mount RE adj. LCA/UCA's beard triple thick limit straps rusty's steering box brace truckfarm pre-runner bumper intake / exhaust procomp lighting system... yada yada yada [URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
