5.9 Alternator Upgrade - Page 2 - JeepForum.com
post #16 of 17 Old 06-23-2013, 05:58 AM
RCTruckStop
I've done this, so below are a couple of notes. The writeup above is excellent, by the way.
> I had the guy at Advance Auto, where I bought my new 136 amp alt, swap the pulleys. He gladly did it.
> The alternator is secured with a two-pice bracket. When I did my swap, the metal piece metal piece also needed to be grinder. I painted the metal bracket before reinstalling. Nobody will ever see it, but it won't rust up in a day like bare metal.
> The boot for the main battery cable is keyed, so you can either use the old one, as mentioned above, or snip the little plastic tab off like I did.
Replacing the alternator on an XJ in kind of a PITA anyway, so if you have to do the chore you might as well upgrade the alternator. The Mean Green alt is nice, but is a solid $400. A 1998 Grand Cherokee V8 136 amp unit is a much better buy.
RCTruckStop is offline
post #17 of 17 Old 12-05-2014, 01:23 PM
bluejunior
bluejunior's Avatar
Just want to throw my .02 on this: the 5.9 durangos had a 160 amp alt with the same housing. The mod/installation is exactly the same as the GC 136 amp.
bluejunior is offline
looking for 99+ alternator upgrade jersey_jim XJ Cherokee Technical Forum 8 12-29-2010 10:50 PM
'90 XJ Alternator Upgrade AbkshelbyXJ XJ Cherokee Technical Forum 7 05-06-2007 07:09 PM
XJ Alternator Upgrade XJH-007 XJ Cherokee Technical Forum 4 04-26-2006 11:39 AM
alternator upgrade dieselkiller XJ Cherokee Technical Forum 10 02-08-2006 06:48 PM
Alternator Upgrade Godchaser490 XJ Cherokee Technical Forum 3 12-05-2004 10:38 PM
