Quantcast 5.5" LA and 35's...flex pics - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 5.5" LA and 35's...flex pics
Old 11-30-2007, 01:08 PM   #1
00_WJ
i wanna see what kind of flex i can expect with this setup... thanks guys
00_WJ is offline   Reply With Quote
Old 11-30-2007, 01:41 PM   #2
Erek.Smith
You can look through the XJ Wheeling Pic topic.
White 2WD 1995 ZJ 4.0
Jesus the Christ is my Lord and Savior. I know Him, do you?
Future Mods: get it working correctly
Erek.Smith is offline   Reply With Quote
Old 11-30-2007, 01:55 PM   #3
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Not the LA kit, but both of RE's 5.5" kits flex the same amount (it's limited by the shocks and other things, not by being long-arm or not). The front actually droops a bit more than in those pics. Here's a better shot of the front at full droop, with much larger tires now.
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Old 11-30-2007, 02:44 PM   #4
UKJeepThang
Jason
Thats a serious amount of articulation given that you have B/W's fitted.
I'm looking to get the same amount once I've upgraded from my 4.5 RE lift to 5.5 RE. (I don't want to go the long arm route)
What shocks are you using there, how much bumpstop and have you trimmed back to the max, just allowing enough to fit the B/W's? What other tricks have you got going under that front?
1998 XJ
RE 4.5 inch superflex lift, RE GEN2 disconnects, 15x8 Crager 352's, 33x12.5x15 BFG MT, ARB Lockers Front and Rear, 4.56 Diffs, Cut & Tap Short Shaft Conversion, CV Rear Prop, B&M Transmission Cooler and Gauge, Bushwackers Cut-Outs, Skid Row Armor, AJ's SuperRails, LeBaron Hood Vents, KargoMaster Rack, Safari Snorkel, KC Daylighters, Midland CB, Brantz Navigation
Loads a mud!!
UKJeepThang is offline   Reply With Quote
Old 11-30-2007, 03:45 PM   #5
Vendor
1995 XJ Cherokee
The fenders are trimmed higher than the inner lip of the BWs. I'd already trimmed them before I got the flares. I basically cut off the flared section of the fender itself, then angled the front forward a bit more.
(I've trimmed a lot more since then though, and left the BWs off for good I think -- http://farm1.static.flickr.com/231/475029271_43f96ebbf7.jpg ).
Current front shocks are 10" travel Bilstein 5150s, with JKS shock adapters and BPEs. Bumpstops are 3" RE pucks on the axle with Daystar poly snubbers up top (~1.5" longer than stock). Only 'trick' I've done really is to bevel the top edge of the RE bumpstop pucks. With the sharp edge they have normally, my coils would catch on them and BOING, plus it broke one of my bumpstops because the stops hit the edge of the pucks and not the top, particularly on the driver-side. If you loose closely, you can see the bevel I cut into the top of the pucks.
The trackbar also bottoms out on the axle bracket, limiting my driver-side droop, but only by about 3/4" or so vs where the shocks would limit.
Long-arms have the potential for more droop, but in the regular configuration both RE 5.5" kits are limited by the shocks and trackbar. With some custom work, you could get a lot more travel using a long-arm setup, but IMHO droop past the point of unloading your coils doesn't really do you any good.
Old 11-30-2007, 05:16 PM   #6
kyro
wow look at the tire starting to fold what pressure you run in those monsters..
looks kewl
1997 Green TJ, 2.5" lift, 2" body lift 33" MT tyres, Snorkel, JKS Discos, RE Upper and lower front Adj, ARB Winch bar, 4.88 gears and ARB lockers
http://www.sunshinecoastjeepclub.com
kyro is offline   Reply With Quote
Old 11-30-2007, 05:21 PM   #7
Vendor
1995 XJ Cherokee
I think they're at like 4 or 6psi. they're also bias ply on beadlocks.
Old 11-30-2007, 06:13 PM   #8
Jeepernick
2008 XJ Cherokee
Nice flex yo
Jeepernick is offline   Reply With Quote
Old 11-30-2007, 06:15 PM   #9
kyro
haha kewl great pic
Old 11-30-2007, 06:17 PM   #10
Jeepernick
2008 XJ Cherokee
5.5ish, TNT Long Arms, 35 mtrs... such, see my spex page for details
http://home.comcast.net/~nickbaldwin/site/?/photos/
I dont have any pictures of full flex, but you get the idea (all 4 tires on the ground)
I have made a lot of adjustments sence those pictures too
Old 11-30-2007, 09:08 PM   #11
JeepnTXJ
It's 6.5", but you should expect something like this and what everyone else has posted:
'00 XJ Classic, 4.0, AW4, 231 w/ SYE, Rusty's 6.5" Long-Arm, Tomken HD shackles, 35x12.5x15 BFG KM2s on Ultra EN4CER Type 181's, PSC box and pump, TnT HD tie rod, Ford 8.8 axle swap, 3.73's, Olympic Top Hat rack, RigidCo bumpers F/R, RigidCo rock rails w/ unibody stiffeners *SOLD*
www.texasjeepowners.com
JeepnTXJ is offline   Reply With Quote
Glock Forum
