4x4 problem - JeepForum.com
post #1 of 4 Old 07-19-2014, 09:52 PM Thread Starter
1badXJ90
1990 XJ Cherokee
4x4 problem
Just bought a 90 xj and can't get it out of 4H(part time). The lever doesn't want to go down and I don't want to force it to hard. Idk if its a linkage problem or what I just need advice
1badXJ90 is offline
post #2 of 4 Old 07-20-2014, 07:39 AM
93gc40
Get all 4 wheels off the ground and then shift it.. Or try shifting while on dirt and barely rolling. Crawl under shift it by hand.. You might as well adjust the linkage while your at it.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 4 Old 07-20-2014, 08:35 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's the proper way to shift it.
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual. The suggestions in ITALICS are mine.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I let off the gas, throw the lever, and then tap the gas and let off.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
To shift out of 4L, shift the transmission into neutral with the vehicle stopped, shift the transfer case lever to 2H, then to D if you have an automatic, or into first gear with a manual, and continue on.
Revised 01-31-2014
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 4 Old 07-21-2014, 02:51 PM
sAe23
1995 XJ Cherokee
Have you tried the "backing up a few dozen feet or so" trick?
sAe23 is offline
