#1 | |
4x4 operation questions from a newb
ok I am semi familiar with the way the 4wd works
but I would like to know exactly how it works basically my question is When I pull the lever next to my knee on my XJ what happens is it cable operated or vacuum and which ever way it is what actually engages when I am driving down the road in 2wd what is spinning and what is not I know this may sound like general knowledge to most of you guys but this is my first 4x4 and thats what this site is for me in the early stages of my XJ ownership its a research tool thanks in advance guys
DAILY 96 S10 ex cab stepside 4.3 5spd ZQ8 05 LJ RUBI 6spd 2" BB, 1.25" BL, RE genII disco's, 33" procomp XMT's |
#2 |
Resident Audio Guru
since you have a 99, your front axles are always "locked" into 4wd, your front driveshaft is spinning, but the only thing open is in the Transfer case itself.
no cables or vacuums, direct metal linkage to the transfer case i believe when you pull the lever the transfer case locks into 4wd and the gives power to the front axles HTH matt
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#3 |
Don't sweat asking questions, it would take a fair amount of searching and reading through many random posts to find all that info on your own.
There are several on this forum more knowlegable than me but to start you off; pulling the lever physically puts the Tcase into 4WD mode via a mechanical linkage... power to both axles. When your in 2WD your front driveshaft still spins, but its because the front wheels are turning it, not because your engine is. This would be different if you had the vacume disconect front axle, but that is a different story. Have fun with your jeep!!
'96 XJ -- 4.0L High Output -- NP 231 -- Chrysler 8.25" 235/75/15 Kumho Road Venture AT KL-41 --Really good tire. Cheaper than BFG ZJ coils up front (1.5"). Full length AAL from donor XJ in back (1.5" - .5" of sag = 1"). No rear swaybar -- Homemade disco's -- B&M Tranny cooler -- C4x4 Tow hooks -- Class III hitch -- Flomaster 40 -- Warn Skid Plate |
#4 |
thanks soooo much guys
its probably a little worse on mpg and a little extra wear and tear on front diff components but to be perfectly honest with you I am so sooooo sooooooo glad that my t-case is a mechanical linkage I am big into S10's as well but mainly on the 2wd side but the vacuum actuated setup on the S10 sucks I have heard horror stories of a guy getting down in the woods and the actuator failed and his buddy had to drive the truck while he walked next to it "SUCKING" on the vacuum line to keep it in 4x4 because it wouldnt come back up outta the woods in 2wd the more I learn about the XJ's it really sounds like my 99 was a REALLY good year to buy it has ALOT of the good stuff everyone wants plus mine is a 5 spd which makes it even better in my eyes thanks again guys
#5 |
I have a 91 XJ it has the vacuum actuator to engage th front axle. that is all the vacuum does. as long as you keep this actuator in good shape, it's not a bad system. You can replace the vacuum line with a cable. I had the actuator stick open on me 1 time. I removed 4 bolts tapped the actuator on the concrete 2 or 3 times and presto! it never gave me trouble again. that was 5 years ago.I make it a point to find an excuse to put it in 4x4 once every couple of weeks just to make sure it is working.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
