-   -   4X4 front axle problem 93 Cherokee sport (http://www.jeepforum.com/forum/f11/4x4-front-axle-problem-93-cherokee-sport-1505349/)
Haas2745 04-06-2013 11:52 PM
I have a 93 Cherokee sport 4.0 high output 6 cylinder. Before I got it there was an axle replacement and it seems that it is for a different 4x4 setup. I don't know if it would be easier to find an original axle and install that or to convert over to a new 4x4 setup. My problem is that I don't know what year the new axle is or if I will even be able to find an original axle.
kippen 04-07-2013 01:16 AM
post a picture of the axle or use this to identify it: http://www.cherokeetalk.com/forum/f6...ication-12011/
xjfever 04-07-2013 03:48 AM
What is the issue you are having with it?
Haas2745 04-07-2013 11:24 AM
I have the dm 30. I will put up pictures soon tho. As of now I have no capability of 4wd. I think the axle is for a different type of 4wd than the original.
xjfever 04-07-2013 12:23 PM
Other than having a vacuum disconnect axle with no vacuum source or having the wrong gear ratio, any dana 30 axle should be compatable as long as it came from a TJ, XJ, YJ, ZJ, MJ. If it is a vacuum disco axle you can fix it to where it will work in 4wd without a vacuum source.
Haas2745 04-07-2013 01:14 PM
How could I go about fixing the problem than?
Haas2745 04-07-2013 01:15 PM
I don't know much about this. If I'm right the jeep is vacume hookup but I think the axle is something else
Haas2745 04-07-2013 01:45 PM
3 Attachment(s)
this is what i currently have for my front axle
Camfam07 04-07-2013 01:51 PM
looks like the vacuum disco d30... I would just look into getting a High Pinion dana 30 from a 92-96ish xj and that will take care of your issue stronger and its a direct swap.
xjfever 04-07-2013 04:18 PM
You can manually lock the axle and it will not hurt anything, the newer ones came from the factory with a solid axle and locking your vacuum axle will givethe same results.
http://api.viglink.com/api/click?for...36536963790110
You can do it this way.
http://api.viglink.com/api/click?for...36536972405811
Or this way.
Haas2745 04-07-2013 10:31 PM
I think I'll look into the high pinion Dana 30 than mabe converting it
Haas2745 06-12-2013 01:47 AM
I did finally get the posi lock kit. And found out that my gear ratios are off. I am currently looking into a junkyard that will have my ratio which is a 3.55. I now understand this stuff Alittle more than I did before
The time now is 03:07 PM.
