is the 4x4 engaging? - JeepForum.com
post #1 of 5 Old 09-02-2012, 10:36 PM Thread Starter
olebluejeep
1993 XJ Cherokee
My 86 xj will go into 4lo like I can feel the low gearing...but I don't think the front wheels are actually pulling along. I didn't see them spin either. Any ideas?
Stock Jeeper
olebluejeep is offline
post #2 of 5 Old 09-02-2012, 10:42 PM
Spladow
I can definitely feel (in the steering wheel) when I am in 4HI or 4LO. Just my 2 cents on that. Does it feel, I guess "stiffer" turning when in 4x4? flex the suspension, get one front tire off the ground and see if it spins. or jack the whole Jeep up a little off the ground and put it in gear, see if the fronts spin (be careful when doing this, think safety above all). just a couple thoughts.
Spladow is offline
post #3 of 5 Old 09-02-2012, 10:45 PM
connor0770
crawl under the Jeep and make sure you are in 4-lo. Check your linkage. try and flex it out until one of your front tires is spinning and the other isn't.
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #4 of 5 Old 09-03-2012, 07:49 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'll bet you've got a vacuum issue with your front axle. Here's a 20 minute cure for that.
http://www.cherokeeforum.com/f51/fre...ss-91-a-38629/
cruiser54 is offline
post #5 of 5 Old 09-04-2012, 09:54 AM
mountainjock
1988 XJ Cherokee
COLORADO JEEP CLUB MEMBER # 312
88 XJ 3" Pro comp lift 31/10.50
231 TC
4.0 I6
mountainjock is offline
