4x4 - JeepForum.com
post #1 of 17 Old 07-10-2010, 02:00 AM Thread Starter
1993F250
1990 XJ Cherokee
4x4
ok so this may be a "newb" type question and while im not new to working on stuff i havnt had anything with a part time 4X4 in it. can someone please explain to me what exactly part time 4X4 does? is it like a front end limited slip or what? and how would i be abe to tell if its stuck in part time 4X4? thanks for any input.
1993F250 is offline
post #2 of 17 Old 07-10-2010, 02:34 AM
Mike318_
Give this a read. Transfer Case If that doesn't answer all your questions, or you have more after reading that, post them up, and somebody I'll help you out.
~ Mike
Originally Posted by soul_Less View Post
"Mike318: Where there's a problem, he's the solution." :rofl::rofl:
Mike318_ is offline
post #3 of 17 Old 07-10-2010, 02:52 AM Thread Starter
1993F250
1990 XJ Cherokee
i read through that and i already know most of it, i didnt see anything about PART TIME 4X4..? did i just miss it orr?
1993F250 is offline
post #4 of 17 Old 07-10-2010, 02:53 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
I'll give you a quicky so you arent overwhelmed by the info given so far and end up over looking some important things that could cost you your axles or T-case. Part time basically means only to be used off pavement or in low traction situations, hence the Part (of the) Time. it transfers part of the power to the front wheels (via the transfer case) for off pavement use, if you have a np242 that has a Full Time 4wd this can be used either on or offroad but will be clearly marked FULLTIME. Try using part time at only appropriate times under appropriate conditions, using the part time onroad or where there is a hard surface that has sufficient traction for on road use can cause the axle to bind when turning and other bad stuff that could eventually lead to either leaving your rig stuck somewhere, pockets empty from repairs, or both.
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #5 of 17 Old 07-10-2010, 03:00 AM Thread Starter
1993F250
1990 XJ Cherokee
Originally Posted by SteelBlue_WJ View Post
I'll give you a quicky so you arent overwhelmed by the info given so far and end up over looking some important things that could cost you your axles or T-case. Part time basically means only to be used off pavement or in low traction situations, hence the Part (of the) Time. it transfers part of the power to the front wheels (via the transfer case) for off pavement use, if you have a np242 that has a Full Time 4wd this can be used either on or offroad. Try using part time at only appropriate times under appropriate conditions, using the part time onroad or where there is a hard surface that has sufficient traction for on road use can cause the axle to bind when turning and other bad stuff that could eventually lead to either leaving your rig stuck somewhere, pockets empty from repairs, or both.
ok that kinda makes sense, but im not seeing the difference between part time 4X4 and 4-HI; is the difference that in part time 4X4 it only gives the front end partial power and the majority of power is still in the rear? while 4-HI gives all 4 tires the same amount of power?
1990 XJ
3" Rancho 5000 lift
D30 front D35 Rear
33x12.5 Mudders sitting on 15" M/T Beadlocks
Doorless
Homebrew discos
Originally Posted by nwiTJdave View Post
Just remember, dress blues make girs drop their clothes much faster than Army puke greens :cheers2::thumbsup:
Originally Posted by Hoobly_Goob View Post
Nothing says "We are a welcoming and kind offroad enthusiast community" like laughing at fat chicks.
1993F250 is offline
post #6 of 17 Old 07-10-2010, 03:02 AM
Mike318_
They're the same thing, just different ways of saying it.
~ Mike
Mike318_ is offline
post #7 of 17 Old 07-10-2010, 03:04 AM Thread Starter
1993F250
1990 XJ Cherokee
so your saying my tranfer case shifts into 2 different positions that are called something different but there not different?
1990 XJ
3" Rancho 5000 lift
D30 front D35 Rear
Doorless
Homebrew discos
1993F250 is offline
post #8 of 17 Old 07-10-2010, 03:12 AM
Mike318_
Kinda.
It sounds like you have a NP242 in your jeep. Which means you have part-time, and full-time 4wd. Part-time is what every 4wd vehicle has in it. Now full-time 4wd is different, sorta. Full-time 4wd uses a limited-slip differential in the transfer case to allow the needed slippage your drive-train needs when on a dry surface, to keep it from binding up.
Edit: I hope that's useful, and makes sense.
~ Mike
Mike318_ is offline
post #9 of 17 Old 07-10-2010, 03:18 AM Thread Starter
1993F250
1990 XJ Cherokee
Kinda.
mostly.
thanks
1990 XJ
3" Rancho 5000 lift
D30 front D35 Rear
Doorless
Homebrew discos
1993F250 is offline
post #10 of 17 Old 07-10-2010, 03:19 AM
Mike318_
mostly.
thanks
Not a problem. You're welcome.
~ Mike
Mike318_ is offline
post #11 of 17 Old 07-10-2010, 04:26 AM
SteelBlue_WJ
take a pic of your t-case shifter... would be nice to see
Bobby
post #12 of 17 Old 07-10-2010, 04:58 AM Thread Starter
1993F250
1990 XJ Cherokee
not my car but same tcase shifter. hopefully it shows up
1990 XJ
3" Rancho 5000 lift
D30 front D35 Rear
Doorless
Homebrew discos
1993F250 is offline
post #13 of 17 Old 07-10-2010, 05:02 AM Thread Starter
1993F250
1990 XJ Cherokee
maybe this one works
the tcase goes 2-part time 4-4hi-nuetral-4lo
1990 XJ
3" Rancho 5000 lift
D30 front D35 Rear
Doorless
Homebrew discos
1993F250 is offline
post #14 of 17 Old 07-10-2010, 07:13 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
In parttime 4x4 there is no slip between the front and rear axles. They will be solidly connected VIA the chain drive in the t-case. This means that the front and rear tires are turning at the same speed at all times and when you turn the wheels there will be binding and something will break if you have good traction. In fulltime the is a differential action between the axles that allows for different speeds front and rear and it can be used at all times on any surface.
xjfever is offline
post #15 of 17 Old 07-10-2010, 04:31 PM Thread Starter
1993F250
1990 XJ Cherokee
makes sense. so i shouldnt use part time unless im in like snow or goin through a big mud hole?
1990 XJ
3" Rancho 5000 lift
D30 front D35 Rear
Doorless
Homebrew discos
1993F250 is offline
Cherokee , Xj Cherokee , 4x4 , Part time 4 wheel drive
