#1 | |
4WD S10 AAL Bastard Pack
I have a set of 4WD S10 springs I can use to make my bastard pack. They are 4 leaf. I already have ZJ coils and RE spacers to get about a 3.5" front lift. Any idea what lift using the main S10 leaf would get me? I guess I can just experiment but I didn't know if anyone had used 4WD S10 leafs before. All the posts I find seem to be about 2WD S10 leafs. Thanks!
#2 |
I got 3.5" out of a four leaf pack
XJ main S-10 Main S-10 Second S-10 Third XJ small Bending the tabs straight up on the factory retainers will do everything you need. If you want pictures I can go out and take shots for you. I also have no Axle wrap, believe me I've tried.
Either our language or our culture needs to be expanded/improved so that there is a polite way to say: Stop talking now, because I am going to stop listening. 99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear. |
#3 |
Little Red Menace
I have :
XJ main S10 Main S10 second leaf XJ third leaf XJ overload I'm getting about 4" of lift out of mine and the ride is good. Firmer than stock, but not unbearable.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#4 |
Does it matter what year s10? Like the older or newer ones?
2001 Sport Silver 170,XXX 100 miles per day DD Rusty's 3 inch 30's PORC SYE 3 Inch Sway Links |
#5 |
Not really. There are spring rate differences though.
#6 |
THREAD HIJACK!!!!
A couple pointers for doing a S-10 bastard pack with a 4 leaf pack. Start off by cutting the spring eyes off. It worked good for me, it will work good for you. ![]() After you're done grind off the main spring pin and separate the packs. ![]() Take the S-10 leaf with the spring retainer and bend the tabs straight up. I did this and used the factory s-10 spring retainers on my XJ. I used a 5/16 bolt as a top clip. I can remove as needed. ![]() Mock up your S-10 main ![]() I found mine to be too long, I cut it down to the white line. ![]() I used a long bolt to align the springs while clamping them together. I also drilled them for a 3/8 center pin. the axle doesn't need to be re-drilled. I did this twice with 3/8 hardware(went taller the second time). Its not that hard if you take your time with good bits. ![]() The only snag. the fix was to use a 1/2-20 bolt and cut the head off. a couple of washer and I was just fine. ![]() Before: ![]() After: ![]() After complete bastard pack: ![]() I haven't had any problems with sag. The after complete bastard pack shows the 31" truxus I'm running now.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
