4WD Problem. Need Much Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 4WD Problem. Need Much Help
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueOfficial Chassis Saver Rust Preventive Truck & Auto Un
Unread 02-26-2014, 11:54 PM   #1
riffraff21
Whenever I put my XJ into 4hi it starts to shudder and jerk forward as if it is hesitant to move forward. It's not making a terrible noise, however it does have a considerable amount of vibration and movement (imagine pumping the clutch really fast while on the gas). The strangest part is that when I move it back into 2hi, the issue is still present UNTIL I put it into reverse, go back a few feet, then move forward.
Any insight you can give me would be helpful. I also noticed the issue on both ice and pavement. I know its normal for 4hi to feel weird on pavement but I feel as if this might be beyond that (maybe not?)
1998 XJ 4.0I6 Manual 5spd 3"lift
the axles are stock as far as I know
Note: The trans mount needs to be replaced
Note of Note: Idk if that is relevant or not
Another Note: I'm a newbie (to Jeeps)(and 4x4)
riffraff21 is offline   Reply With Quote
Unread 02-27-2014, 04:31 AM   #2
RLE
If the transmission mount is deteriorated, it is not going to hold the
trans in place. So, when you put it in 4Hi, the extra torque can make
the trans hop around and cause what you describe.
You should fix the tranny mount asap and see if it helps your problem.
If you don't fix it soon, you'll risk breaking your motor mounts, too,
and then you'll really have a problem.
Since you just got this Jeep, the problem may have existed for a while,
so check your motor mounts, too. (for more info on that, see the "sticky"
at the top of the forum)
You should change all fluids on the vehicle unless you know its previous
service history (eg. you bought it from someone you know well). Engine
oil and filter, radiator coolant, transmission, front and rear diffs. If you
can't get to them immediately, at least top them off.
RLE is offline   Reply With Quote
Unread 02-27-2014, 06:43 AM   #3
M35A2
1995 XJ Cherokee
Are you on dry pavement when it happens?
Volunteer, American Society of Military History. Come see us at http://tankland.com/
M35A2 is offline   Reply With Quote
Unread 02-27-2014, 07:32 AM   #4
riffraff21
Fluids have been changed and I am replacing the trans mount today and I'll let you know if that helps. I noticed it on both pavement and ice.
Thanks for the responses!
Unread 02-27-2014, 07:51 AM   #5
cory4um
Any insight you can give me would be helpful. I also noticed the issue on both ice and pavement. I know its normal for 4hi to feel weird on pavement but I feel as if this might be beyond that (maybe not?) )
Having to reverse for 4wd to disengage is common.
You can try adjusting the transfer case linkage ( how-to can be searched here).
Adjusting the linkage is key for smooth operation.
A worn tranny mount will cause the driveline to drop a bit. Enough to pull the linkage out of wack..
Adjusting linkage may also fix your vibration or surges as it may not fully be engagingthe 4wd..
How does 4 lo work?
cory4um is offline   Reply With Quote
Unread 02-27-2014, 08:08 AM   #6
riffraff21
Well that's good to know that reversing it out of 4wd is normal. I haven't tried 4lo because I'm really hesitant to do so (4hi is interesting enough). I will swap the trans mount and tighten up the engine mounts to see if that works. After I do that I will check out 4lo to see if its in the same way. Will update.
Unread 02-27-2014, 09:44 PM   #7
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here is the factory recommended procedure for shifting.
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual. The suggestions in ITALICS are mine.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I let off the gas, throw the lever, and then tap the gas and let off.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
To shift out of 4L, shift the transmission into neutral with the vehicle stopped, shift the transfer case lever to 2H, then to D if you have an automatic, or into first gear with a manual, and continue on.
Revised 01-31-2014
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
Refresh*Connections*Before*Replacing*Components
cruiser54 is online now   Reply With Quote
Unread 02-28-2014, 12:43 AM   #8
Renix
1989 XJ Cherokee
Replace tranny mount, adjust transfer case linkage, replace front diveshaft u joints they probably are old and worn. If these don't fix it more info is needed. I.e. Transfer case type, lift size if any, front pinion angle if lifted, and if you don't have a full time 4 wheel drive transfer case don't put it in 4hi or 4lo on pavement.
Renix is online now   Reply With Quote
Unread 03-01-2014, 11:54 AM   #9
riffraff21
Ok so the tranny mount has been replaced along with the front U-joints. This has made things a lot better however there I have found some play in the front driveshaft, I have a feeling that its on its last leg.
Unread 03-01-2014, 12:23 PM   #10
RLE
Congratulations on the progress.
Where exactly is the play?
In the driveshaft slip yoke?
In the front u-joint?
In the CV unit and its two u-joints?
In the pinion yoke?
You can get a front driveshaft from a junkyard, although for a manual XJ
they are harder to find than for an automatic. If you can't find a good
one for a manual XJ, you can have one that is from an automatic shortened
and balanced at a driveline shop easily enough.
If the play is in the pinion yoke, then that is another matter.
Unread 03-01-2014, 03:33 PM   #11
riffraff21
Its the slip yoke. I'm gonna start looking around for a used front driveshaft in the nearby junkyards and get that replaced. If it doesn't eliminate the problem for good then I will consult this thread and all you nice people again.
Thanks for help!
