There is a switch on the transfer case for the dash lights. 1997-2001 you can unplug the wire harness and use a paperclip to connect the two pins. If the dash light comes on, the wire harness and light bulbs are good, and you probably need a new T-case switch.
. Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
