4L swap questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 4L swap questions
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChTJ Wrangler 4" Rough Country Suspension Lift Kits in
Unread Yesterday, 09:28 PM   #1
bronjovi
4L swap questions
I have a 96 xj with 2.5l. 5 speed. Looking to swap to 4l from an 87 xj with 5 speed. Is this possible? Of course ecu rear end, drive shaft, trans and engine from 4l will be used.
bronjovi is offline   Reply With Quote Quick reply to this message
Unread Today, 04:33 AM   #2
biztyke
i'll let others chime in, but i am pretty sure there are modifications to the engine bay needed(room, engine mounts, etc). if you have the donor jeep side by side and want to spend the time, then yes it is possible. but it would be easier to just sell the 2.5 and buy a 4.0.
biztyke is offline   Reply With Quote Quick reply to this message
