-   -   4 wheel drive problem (http://www.jeepforum.com/forum/f11/4-wheel-drive-problem-1543613/)
tannerlw 07-01-2013 02:22 PM
I have a 1999 jeep cherokee. Automatic, 4.0 straight 6 stock motor in it. I have the command-trac 4 wheel drive. My 4 wheel drive has been broke for a couple months now and I don't know what's wrong with it. When I try to shift it in to 4 hi or 4 hi it does nothing. The handle for it is almost loose. Does anyone know how to fix this!?
Thanks in advance
Paradise XJ 07-01-2013 03:01 PM
Have you crawled under there to look at the linkage? The linkage is very simple, but if it's loose or not connected or even out of adjustment, it's worthless. It's not "push-button" 4 wheel drive. The "handle" is connected to the Transfer Case (the thing that makes 4 wheel drive work) by a EZ Squeegee linkage system.
Originally Posted by 94TwoDoor (Post 15618959)
The linkage is just a collection of metal pieces that connect the 4WD shift handle inside to the side of the transfer case, look up towards the drivers side of the t-case from underneath with a flashlight while someone shifts the 4wd shifter and you'll see it moving. Just make sure it's actually moving the arm on the T-case. I know mine got pretty rusty and the hinge parts were trashed.
Note: I found this after a grueling 5 second search on Google.
The time now is 02:51 PM.
