Quantcast 4.88 regear in HP30... need some help w/ what is needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 4.88 regear in HP30... need some help w/ what is needed
Old 12-14-2008, 01:46 PM   #1
flatlander757
Now in the 937
flatlander757's Avatar
First off, yes I know what I'm doing and know how to regear an axle with the dial indicator and in-lbs torque wrench for checking backlash, pinion depth, pinion pre-load, etc.
I am regearing/rebuilding this axle to put under my TJ. It's from a 97 XJ.
I have a list of all the crap I need/want to put into the housing, but it's hard as hell to find it all in one place.
For instance I've found Yukon 4.88s for the D30R from a few places(Redrock 4x4 and Randy's R&P), but I need all the seals, a master install kit, and I'd also like an extra pair of "set-up" bearings to get it right.
If anyone has regeared themselves, then where did you get all the parts from?
Also, aside from the gears, everything else is interchangeable between the HP and LP right? Install kit/carriers/seals? Just want to make sure before I order $400 worth of useless stuff.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Old 12-14-2008, 08:26 PM   #2
flatlander757
Now in the 937
Well I found www.completeoffroad.com and they have a very well-organized site and I found all the stuff I need there... anybody used them before? Good/bad experiences?
Build thread here.
Old 12-14-2008, 08:34 PM   #3
slafferty
slafferty's Avatar
I ordered my 4.88's for d30 and d35. You can't beat the price, the gears and install kit are yukon brand. The package had everything i needed, so theres no complaint about completeoffroad from me
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
http://www.jeepforum.com/forum/f22/slaffertys-2000-tj-build-1121555/index2.html
slafferty is offline   Reply With Quote
Old 12-14-2008, 09:00 PM   #4
dudeinatj
I ordered some ball joints from them and I was very pleased with service. They were on back order and personally called me to tell me that they were going to have them drop shipped from the supplier instead of having me wait until their order came in. I would recommend them.
dudeinatj is offline   Reply With Quote
Old 12-14-2008, 10:11 PM   #5
flatlander757
Now in the 937
Sort of derailing my own thread, but how have those ball joints held up? What's the brand name? I'm assuming this is for your D30? I noticed their joints are hella cheap (like $35 for an upper/lower pair!) compared to about $55-60 each at a local parts store. For the sake of my budget build they're very tempting.
Build thread here.
Old 12-14-2008, 10:21 PM   #6
dudeinatj
Yes, for my D30. I know they are made in the USA with no other markings on the box. Someone over on naxja.org said that they were Dana Spicer. http://www.naxja.org/forum/showpost.php?p=244162777&postcount=10
Glock Forum
