4.5" RC Lift w/ 32's - JeepForum.com
post #1 of 5 Old 02-19-2012, 09:27 AM Thread Starter
Sscheevel15
I am new to this community and I'm doing a lot of research to start my first project. I have a 98 xj sport and was looking into this kit
http://roughcountry.com/jeep_xj_4.html
I want to run 32" tires on it without having to trim. Is that possible and if now could I run 31's? Lastly, is this kit all I would need to get my jeep looking good? I am limited to a budget and don't do a lot of hard trail riding but just wanting something that looks nice and has performance and is easy to install.
Sscheevel15 is offline
post #2 of 5 Old 02-19-2012, 09:36 AM
jeepjunkymike
if you offroad you will have to trim,,,,,im 4.5 and was running 32s,,,but went to 31s and still rubbing when articulating
jeepjunkymike is offline
post #3 of 5 Old 02-19-2012, 09:37 AM
jeepjunkymike
rc kit will work just fine,,
post #4 of 5 Old 02-19-2012, 10:32 AM
alancook17
make sure your wheels have the right backspacing, it will say on rc.com in the details section for the lift what you need and i recommend bump stops. either after markets or keep your stock ones and set 1 or 2 hockey pucks taped together inside your front coil spring before installing it
2001 XJ CHEROKEE ORO Member 325
alancook17 is offline
post #5 of 5 Old 02-20-2012, 08:37 AM Thread Starter
Sscheevel15
Thanks for all of the replies. I will probably end up going with the 4.5" w/ 32's and trim a little. I drive on pavement about 90% of the time so I dont think rubbing will be much of an issue.
1998 , jeep , rc , xj
32's on an XJ with 3" RC lift Haney XJ Cherokee Technical Forum 6 08-20-2010 08:24 PM
3" lift with 32's? johnnieoh1 XJ/MJ Cherokee Non-Technical Forum 2 02-25-2009 06:02 AM
4 1/2" lift w/ 32's 06dm654 XJ Cherokee Technical Forum 21 06-20-2006 11:32 PM
Anybody with 32's and 3.5" of lift? jeepstercfla XJ Cherokee Technical Forum 1 07-17-2004 12:46 AM
Will 32's fit on a 4.5" lift??? MrBill16 XJ Cherokee Technical Forum 1 07-31-2002 11:00 PM
