4.5" RC leafs to 4.5" Rusty's... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 4.5" RC leafs to 4.5" Rusty's...
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 07-04-2013, 12:07 PM   #1
LightningFAST
Hey guys. I bought my Cherokee with a full 4.5" RC lift kit. Rear has been sagging to the right side for some time now. Installing 4.5" Rusty's leafs now. Rusty's uses 6 leafs compared to RC's 5. Jeep has pinion angle shims. I'm assuming I should re-install the pinion angle shims, correct?
Jeep also has 1.75" coil spacers and lift shackles. Thanks and happy 4th everyone!
Sold: '95 YJ
Sold: '97 TJ
Current: '98 XJ
LightningFAST is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 04:57 PM   #2
MOBBiN
MOBBiN's Avatar
Yes reinstall the shims
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 05:00 PM   #3
LightningFAST
Thanks for your reply. I literally just put the Jeep back on the ground now. Pinion angle is not horrible looking with my eyes but I am going to measure it and see what I need. The shims were mated to the RC leafs and one broke into pieces, plus it wouldn't fit around the alignment pin on the Rusty's leafs...so I'll order new ones tomorrow...now I want to see if this sag is gone!!
Sold: '95 YJ
Sold: '97 TJ
Current: '98 XJ
