4.5" leaf springs - JeepForum.com
post #1 of 10 Old 12-30-2012, 05:02 PM Thread Starter
ecsbabydaddy
4.5" leaf springs
I just scored some nearly new 4.5" rough country leaf springs cheap. Not sure if I want to lift my xj that high. Question is, can I use them for a bastard pack, and if so, which leaves should I use? Trying to do a lift on a budget. I'd be happy with 2-3 inches.
ecsbabydaddy is offline
post #2 of 10 Old 12-30-2012, 06:17 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Yes, you can use them for a bastard pack. I would likely use the top leaf of the lift springs with the rest of the XJ pack and see where that gets you. You will likely need to do some trial and error fitting to get it where you want it. That is pretty easy to do though once you have both leaf packs taken apart.
xjfever is offline
post #3 of 10 Old 12-30-2012, 06:22 PM Thread Starter
ecsbabydaddy
Top leaf being the second from the main. Or the main itself?
post #4 of 10 Old 12-30-2012, 06:38 PM
donthelegend
If you got them cheap but don't want to go that high, I'd try reselling them for enough to buy the leafs you want rather than turning them into a bastard pack. But no, there's no reason you can't make a bastard pack out of them.
donthelegend is offline
post #5 of 10 Old 12-30-2012, 07:22 PM Thread Starter
ecsbabydaddy
I'd like to keep them. My thoughts are to use the second from the top leaf for starters. Just curious as to how much lift this will net.
post #6 of 10 Old 12-30-2012, 09:12 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Can't know without trying it. Once you have it jacked up and both packs apart, you can lower the weight on the axle with different combinations and measure to see how much lift it has gained before actually putting the pack together. Be sure to take a before measurement though.
xjfever is offline
post #7 of 10 Old 12-31-2012, 09:52 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Their Rough Country springs.
Install them and just watch them sag to a lower height...
I would try to sell them on myself, preferably to someone that is not a friend, as my experience with RC stuff leave me thinking of a BUMPY ride followed by a sagging ride.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #8 of 10 Old 12-31-2012, 04:19 PM
AmbuGrl
AmbuGrl's Avatar
I have RC and its not sagging at all. The PO used a bastard pack that was sagging miserable within less than a year. I have run mine with 0 sag at 4.5 full packs
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #9 of 10 Old 12-31-2012, 04:33 PM Thread Starter
ecsbabydaddy
Well if I run it, looks like ill need a ton of stuff for the front end too. I'm trying to lift my xj on a budget. Already got jk shocks, so maybe I'd be better sticking with a 2" lift and doing a bastard pack in the rear.
post #10 of 10 Old 01-01-2013, 11:19 AM
leftlanetruckin
XJ on 37's
All depends on the springs used in a BP though doesnt it? Too weak, and they will sag. Too strong and they wont flex. I seriously doubt anyone works out the weight of each corner, then the rating of each spring, and build to suite. They normally just start grabbing springs and keep their fingers crossed.
Past customer of RC myself, and would never return. I know they had a thread in the XJ section a while ago, but seemed to still have the same issues of sagging. Get what you pay for in this world, unfortunately.
Thus why you hear of how good RC customer service is all the time, and not how good their products are
Not a clue on how good IRO customer service is, never had to use it.....which is kind of the point.
Martin
