4.5 inch suspen. lift kit install tips! - JeepForum.com
post #1 of 8 Old 05-06-2007, 02:43 PM Thread Starter
Country Cracker
Country Cracker's Avatar
HI, I JUST BOUGHT A 4.5 INCH SUSPENSCION LIFT KIT FOR MY JEEP CHEROKEE 96'. I HAVE A SPRING COMPRESSOR ALREADY AND I JUST WANT TO KNOW WHAT STEPS I SHOULD TAKE TO PREPARE FOR INSTALLING. PLEASE NOTE THAT THIS JEEP IS A 2WD. NO TRANSFER CASE DROP OR ANYTHING! I WOULD ALSO LIKE IF ANY1 COULD TELL ME ANY GOOD TIPS THAT WOULD HELP THE INSTALLING EASIER. THANK YOU SO MUCH EVERY1!
Country Cracker is offline
post #2 of 8 Old 05-06-2007, 02:48 PM
99_XJ
Buy a locker get recovery points.....
1999 Steel Blue XJ Sport-RE 4.5" Lift-33x12.50 XTerrain's-4.56's-ARB's F&R-Alloy USA 30 spline axles-AGR SB2 Steering Box-AGR Steering Pump-Currie Currect Link Steering Upgrade-Custom OBA.... Sold :(
1990 Wrangler Islander YELLOWChevy 350 V8 32" Swampers
99_XJ is offline
post #3 of 8 Old 05-06-2007, 02:49 PM Thread Starter
Country Cracker
A Locker? Sorry Not Exactually Sure What That Is
post #4 of 8 Old 05-06-2007, 02:58 PM
Meatroach
Meatroach's Avatar
1992 XJ Cherokee
I'd say start with spraying all your bolts & ***** you'r going to undo with Fluid Film or PB Blaster or the like, for good week before starting, if you haven't already.
good luck.
XJ
[COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid
Meatroach is offline
post #5 of 8 Old 05-06-2007, 02:59 PM
XJK
The Guru of Nothing
XJK's Avatar
wait your jeep is 2wd?
well if it were me i wouldnt lift a 2wd vehical, i would just sell it and buy a 4wd but thats just me.
if your going to keep the 2wd then i would highly suggest locking the rear diff. A "locker" is a device that goes in the diff and will lock both of the axle shafts together to create equil power between the two shafts, this results in better off road performance.
Try doing a search for "lockers" if you need more information about them.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #6 of 8 Old 05-06-2007, 03:07 PM
Low Pressure
Low Pressure's Avatar
1993 XJ Cherokee
yup, pb blaster your screws and nut a week or so before.... prevents from breaking nuts and bolts.
if its only a street driver you do not need locker
Low Pressure is offline
post #7 of 8 Old 05-06-2007, 07:21 PM
Vrrooom
Just curious - why lift a 2wd? The point of a lift is to usually get you places that a stock ride height cannot get you. These places also require the use of all 4 wheels...
14 WK2 Diesel Limited, QT2, 32" Duratracs
09 Z06. Cam, other go fast goodies
98 XJ, JK D44s locked, armored, 37s, trail queen / sold
07 JK Rubi, 37s, bumpers, armor, mild lift, DD / sold
Vrrooom is offline
post #8 of 8 Old 05-06-2007, 07:29 PM
Topgun514
1988 XJ Cherokee
dude, i hope there is no offense taken because i was and still am slightly, a jeep noob...if you just got a 4.5 inch lift, and dont know what a locker is, then im afraid you may be doing this the wrong way...
4x4 is THE ONLY way to wheel IMO(in my opinion)
and a 4.5 inch kit requires bigger tires...your gonna want some big tires and trim, and then regearing, and your not gonna want some axles, and a lift isnt the easiest work...
if your gonna just show your jeep and not wheel it, then your lift is okay but if you plan on some decent wheeling, your gonna want 4x4
a locked 2wd is strong, but i would take open diffs 4x4 than a locked 2 IMHO
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
97 XJ shaking after 3 inch RC lift install bostonjeeper XJ Cherokee Technical Forum 5 01-01-2010 11:16 PM
5 inch lift install questions jeep12827 XJ Cherokee Technical Forum 10 09-22-2009 04:51 AM
RE 5.5 Install tips longtravel1 XJ Cherokee Technical Forum 2 03-12-2009 07:42 PM
Any tips on installing a procomp 3 inch lift? Rob Hollar XJ Cherokee Technical Forum 3 03-18-2007 04:23 PM
RE 4.5 Install tips Maco98XJ XJ Cherokee Technical Forum 1 04-12-2006 12:00 PM
