4.5 inch lift trac bar questions
#16 | |
forum supporter
No, the guy above posted a picture of 6" lift on stock trac-bar, but those are deffinately not stock control arms. Are you sure you know what you are talking about, or are you just repeating what you've read?
#17 |
Hello, post #2, Got a ? about my XJ but can't start a new post yet. What I got is an 86 With the GM v6 and the Chrys. 904 trans. 4X4. I also got a 318 in the garage. Has anyone put a 318 in an XJ using a 904 SB v8 housing, with the tail end of the trans from current set up? I haven't done a lot of looking, but seems to me to be quite do-able. Would be one beasty little 2dr 4x4 XJ.
Last edited by gonzo99; 01-01-2009 at 09:36 AM.. Reason: found this topic elswhere |
#18 | |
blue jeep club member 174 2001 xj- 2 inch bb moabs 1998 zj 5.2- 245/75's moabs |
#19 | |
forum supporter
#20 |
I lifted my 5 inches with stock control arms and stock track bar. lasted 2 months before Death Wooble set in. Took it on one trip like that. Went out and bought a RC adjustable track bar and took it in and got the alignment done. Can you do it, Yes, will it last long before you start having troubles NO. RC adjustable track bar is around $100 bucks new.
Tweeternpi New 2003 Green Tj Rubicon. 4 Inch lift 305/70/16 MTR's Milemarker 8000 winch. OLD 92 Cherokee Larado. Red and Grey. 7" lift, trim fenders Long arm 4:10 gears with lockers and 35/12.50/15 Toyo AT. So to be parted out to the wifes YJ. |
#21 | |
#22 |
I would not run over 4-5" with stock LCAS. My boss ran 5.5" of lift on his ZJ with stock arms and track bars. It drove and rode horribly. The arms shown in my pictures are RE adjustable super-flex arms intended for a 3.5" lift. They were adjusted to 1/4" longer than stock. Stock upper arms.
#23 |
lol gotta love how my original post was can i lift 4.5 without adj trac bar and u get people who somehowe want to add there 2 cents in about driving around with stock lcas.. when i clearly mention i have adj lcas... and there 2 cents is just repeated from wat they have heard from an earlier thread.. please guys read the hole thread start post to last post then add input.. im not bein a jerk but i just see it happen alot.. thanks for all of the help tho guys and tryin to help out a fellow jeeper which in all actuality is what this forum is about
#24 |
buy a new ****ing tracbar????? if you cant afford to do it right, dont do it.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
