Quantcast 4.5 inch lift trac bar questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 4.5 inch lift trac bar questions
4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 Trans
Old 12-30-2008, 11:17 PM   #1
jeep12827
1987 XJ Cherokee
hey guys so i got everything i need to upgrade to my 4.5 inch lift all rough country.. i now have a 3 inch rc lift installed already with stock trac bar not redrilled yet no need to with 3 inch. well i dont have the money rught now for a new adj trac bar so could i possibly redrill the old mounting plate for a temp fix to get the rest of the lift on then buy a new trac baar in about 2 months?? or is 4.5 inches wayy to much??
jeep12827 is offline   Reply With Quote
Old 12-30-2008, 11:44 PM   #2
FleXJ00
3" would be the MAX for a relocated track bar...
if your going 4.5" you would need to invest in an adj. trackbar...
check out iron rock offroad...
BLACK JEEP SOCIETY #256
2000 Cherokee Sport 162K
...with some stuff
I SUPPORT ROUGH COUNTRY
AND TREADWRIGHT
FleXJ00 is offline   Reply With Quote
Old 12-30-2008, 11:46 PM   #3
jeep12827
1987 XJ Cherokee
yeah but i figured if i already have 3 inches and havent had to touch the trac bar yet the extra 1.5 inches i will have to move it slightly...
Old 12-30-2008, 11:53 PM   #4
jeep95xj
1995 XJ Cherokee
At 3" yout stock track bar is to short. Id put $ on your axle not being centered. May look like it is from a quick glance but if you measure, im sure it's not. Even a 1/2" off can make a big difference. Dont install the lift till you have the new track bar. You do have new lower control arms right? While you can get away with stock uppers id strongly advise you change them to
jeep95xj is offline   Reply With Quote
Old 12-30-2008, 11:55 PM   #5
FleXJ00
with my 3" lift my axle was about an inch off center...
dont leave your stock trackbar on there at 4.5"...your just asking for trouble...
...with some stuff
AND TREADWRIGHT
Old 12-30-2008, 11:58 PM   #6
broncofire75
I'm still usin the stock track bar wit a redrilled hole on the axle...it workd til I wheeled it....now the hole is wallowed out bad an pops pretty good...I'd recommend a ask now. Look for a good used 1 on craigslist, eBay an here. I found a good Rustys for 75 shipped. Saved a good chunk a change
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote
Old 12-31-2008, 08:12 AM   #7
jeep12827
1987 XJ Cherokee
alright so thats the answer.. no lift yet without trac bar.. thanks guys i appreciate it .. and yet i already have lcas, sway bar disconnects 4-6 inches, t case drop, rear 2 inch shackles, steering stabilizer and now i need coil spacers and trac bar. Thanks everyone
Old 12-31-2008, 09:41 AM   #8
jeep95xj
1995 XJ Cherokee
Your have control arms also right? You can get away with stock uppers even though its not a good idea however you have to change the lowers. Thats not optional
Old 12-31-2008, 12:40 PM   #9
91xjgawes
uhh yeah it is "optional"you can go up past 6" with the factory arms, although it would like like crap
man go ahead with the lift...just because your wheels are off center you can stll get an alignment..
half these people only repeat what they hear on this forum and have no real life experience with it
blue jeep club member 174
2001 xj- 2 inch bb moabs
1998 zj 5.2- 245/75's moabs
91xjgawes is offline   Reply With Quote
Old 12-31-2008, 12:44 PM   #10
jeep12827
1987 XJ Cherokee
yes i already have adj lowers
Old 12-31-2008, 12:48 PM   #11
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Can you post a quick picture of a 6" lifted XJ on stock arms? I would like to see it, but would hate to ride in it.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 12-31-2008, 12:55 PM   #12
justanotherjpr
I ran 6" of lift with a stock track bar, re-drilled. My axle was off center and it drove so/so. You can get away it for a little while, but your tires may wear a little funny.
Stock track bar and torn LCA mount repaired, 6" of lift, short arms.
Pic shows stock track bar, torn mount, LCA angle, and 31" BFG MT at 12psi.
justanotherjpr is offline   Reply With Quote
Old 12-31-2008, 04:50 PM   #13
jeep12827
1987 XJ Cherokee
ok.. now idk what to do lol i need more opinions please
Old 12-31-2008, 11:50 PM   #14
jeep12827
1987 XJ Cherokee
bump to 10
Old 01-01-2009, 12:59 AM   #15
91xjgawes
the guy above did and my ole beater 91 has about 5 1/2 on short arms...ride is horrible to say the least but it does work.
Glock Forum
