4.2 crank in a 4.0 block??? - JeepForum.com
post #1 of 2 Old 01-29-2012, 03:47 PM Thread Starter
whiteys_red_XJ
hi tring to get some info on a swap my buddy put into my head i have a 4.0 complete motor and was thinking bout putting the the crank and connecting rods from a 4.2/258 in the 4.0 block has anyone seen this done and is it worth it in the long run as far as gains along with this swap i was goin the port n polish the heads and intake any info ill be helpful
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 2 Old 01-29-2012, 04:28 PM
foggybottombob
foggybottombob is offline
Renix block vs. HO block differences? stretchj MJ Comanche Technical Forum 3 10-28-2011 10:09 AM
long crank, extended crank wheelin XJ Cherokee Technical Forum 0 06-25-2011 08:51 AM
Extended crank, startup, dies...crank again and rough start dcg1 XJ Cherokee Technical Forum 2 01-31-2011 02:03 PM
Any difference between 97 4.0l block and older H.O. block? TheZaZ XJ Cherokee Technical Forum 4 01-18-2010 04:16 PM
new fuse block? am i a block head? 2nd alt? futurefd XJ Cherokee Technical Forum 3 02-12-2007 11:37 AM
