4.10 installation - JeepForum.com
post #1 of 2 Old 04-29-2009, 09:30 PM Thread Starter
Nelg7654
1997 XJ Cherokee
4.10 installation
is this difficult?
should i leave it to the pro's or is this something i can handle with hand tools in an open weekend?
Nelg7654 is offline
post #2 of 2 Old 04-29-2009, 09:38 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Installing gears requires special tools and knowledge. You can usually find 4:10 geared axles out of a 4 cyl. XJ, and this would be the easiest route. Just swap the entire axles over. But if swapping out the gears leave it to the pros. A regear for both axles will be between 1200 and 1500 dollars.
xjfever is offline
PCM Installation??? wangtyme XJ Cherokee Technical Forum 1 09-08-2007 10:58 AM
LCA installation 4x4life XJ Cherokee Technical Forum 9 11-23-2005 04:05 PM
amp installation crazyxj01 XJ Cherokee Technical Forum 4 08-25-2005 04:42 PM
installation VTJeep11 XJ Cherokee Technical Forum 4 07-28-2004 06:17 PM
A-a-l Installation ??? rocknerd XJ Cherokee Technical Forum 6 06-18-2004 09:14 AM
