4.0L Timing belt question - JeepForum.com
post #1 of 7 Old 08-26-2003, 01:36 PM Thread Starter
daveleau
daveleau's Avatar
I have symptoms (I think) of a going timing belt. The engine seems to sound faster and higher pitched when starting and the idle has dropped a bit, which has not been the case in the past. IF the timing belt goes before I can get it replaced, will it destroy the engine? I had a Honda Civic when I was in college and the timing belt went. It belt rods and tore the engine up to the point where I had to get rid of the car. The same happened 3 months later with my replacement car (Toyota Celica), but the engine damage was not there.
So, is the 4.0L engine designed to be able to handle a timing belt failure without destroying other parts of the engine?
Thanks
Dave
'87 Jeep XJ 4.0L 4x4 3" lift 31x1050
First time 4x4 owner w/ a project vehicle (which happens to be an every day driver)
daveleau is offline
post #2 of 7 Old 08-26-2003, 02:51 PM
ChrisinVA
The 4.0 doesn't have a timing belt. It's not an overhead cam engine like you're used to. It just has a plain 'ol timing chain, at the bottom of the engine. They generally last the life of the engine.
I seriously doubt that would be your 'problem'. More than likely it's your idle air motor gummed up.
94 XJ, 4.0/AW4/8.25/242. 145k miles, bought it in march of '02. Rusty's towhook on front, Hidden Hitch out back with shackle. Rebuilt AW4 in January, '03. Kumho MT's on AR767.
ChrisinVA is offline
post #3 of 7 Old 08-27-2003, 10:48 AM
TampaXJ
Im thinking your problem is something with intake. LIke an idle air controller or something to that nature....as far as the engine and serious damage only interference engines cause serious damage when the timing belts let loose...toyotas and hondas(non interference) generally do damage with the water pump goes and seizes the timing belt causing the car to overhead and things inside to warp due to extreme heat...
Space Canoe: Little of this, a little of that...
Pope Wagon: 360 powered XJ...
H2...half the legend, twice the cost....
TampaXJ is offline
post #4 of 7 Old 08-27-2003, 11:49 AM
FourthGenHatch
If the 4.0 isn't OHC than does that mean its a Pushrod engine?
So if that chain broke (if that is even possible?) I heard that on a pushrod engine the pushrods just break but they are easy to fix. Is that true? Do I have the right idea?
Adam Carolla: "The hands down number one choice of car for a stripper is the Jeep Wrangler."
Dr. Drew: "Ironic how a stripper would choose a topless vehicle."
FourthGenHatch is offline
post #5 of 7 Old 08-27-2003, 01:52 PM
TampaXJ
no not really...ok with our engines if the timing chain goes, as long as you stop within a minute or so and shut the car off you'll be fine. now with a cam engine...what happens is the valves open and close, hence the term interference, sowhen the timing belt goes the valves dont get out of the way of the uprising pustons and presto your piston just crushed your still opened valves....
TampaXJ is offline
post #6 of 7 Old 08-27-2003, 03:23 PM
JTruel
Almost all engines are "interference" motors
whether it has a belt or a chain it all works the same. If the belt or gear or chain breaks or jumps (which DOES happen with a timing chain) You have the possibility of busting a few valves. Pushrods are not the weakest link in your engine.. look at a pushrod, most are a little over 5/16 in diameter.. now look at a valve stem.. about 1/8 give or take, which will bend first? You be the judge.
2000 XJ Classic
2005 LJ
JTruel is offline
post #7 of 7 Old 08-27-2003, 07:26 PM
ChrisinVA
Fourth, please don't worry about it. Probably just your idle motor.
And yes...it is a pushrod/overhead VALVE motor. It's a modified version of those inline sixes you see in mail jeeps/CJ's.
Does a 1997 jeep cherokee have a timing belt or timing chain? everhguevara XJ Cherokee Technical Forum 5 08-30-2009 03:00 AM
timing belt d768 XJ Cherokee Technical Forum 10 04-08-2008 10:59 PM
timing belt ilyasXJ XJ Cherokee Technical Forum 3 02-08-2007 04:09 PM
Timing chain or timing belt? '94 Cherokee LPW2 XJ Cherokee Technical Forum 3 05-31-2005 01:11 PM
Timing belt? heathen3226 XJ Cherokee Technical Forum 2 03-15-2004 07:29 AM
