4.0l serial number location - JeepForum.com
post #1 of 6 Old 03-20-2010, 12:45 PM Thread Starter
bigmatt
bigmatt's Avatar
I am looking for the engine serial number.I have the build number off of the motor(006mx05),Is that the serial number?or is there another number i should be looking for?
91yj 4 banger, 265,000 miles,100% stock ,bought it new.NOW SOLD,
03 TJ sport, stock 4.0.dana 44 ,red w/black hardtop
2001 XJ Sport, stock 4.0L 130.000miles,soon to have new motor.)0331 head issue.
bigmatt is offline
post #2 of 6 Old 03-20-2010, 01:23 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
All 4.0L have a casting number cast into them on the drivers side near the motor mount bracket. XJ engine blocks also have a build date number identifying when the bare block was built into an engine.
Block Casting Numbers
Year............Casting No
1987-90......53005535 (8933002665)
1991-95......53008405
1996-98......53020569
1999-04......53010449
I have read in other threads that stamped on the block about halfway up above the starter should be the vin # of the Jeep..........
CJ7-Tim is offline
post #3 of 6 Old 03-20-2010, 01:36 PM Thread Starter
bigmatt
bigmatt's Avatar
Thanks
I will have a look
bigmatt is offline
post #4 of 6 Old 06-10-2010, 11:15 AM
barflyfisherman
Block casting number - 4.0 HO block
Does anyone know if the blocks for the HO 4.0L engines had a separate casting number? I know that heads had different casting numbers.
I was wondering if the blocks did too, due to some minor internal modifications (such as the girdles to reinforce the crankshaft mains).
Hillary Clinton - Wasn't a swirling house supposed to fall on her by now?
I don't kill innocent animals.... only the guilty looking ones!
barflyfisherman is offline
post #5 of 6 Old 06-10-2010, 01:40 PM
CJ7-Tim
CJ7-Tim's Avatar
The block casting numbers are posted above.
CJ7-Tim is offline
post #6 of 6 Old 08-22-2014, 01:57 PM
Wilmingtonite
Is the block casting # the same as the "motor number"?
Wilmingtonite is offline
Need help on parts number sharks9022 XJ Cherokee Technical Forum 0 06-03-2009 09:26 PM
VIN number location on rear hatch 9pt0 XJ/MJ Cherokee Non-Technical Forum 1 09-24-2008 08:13 AM
TC serial number, any way to trace it? firehawk XJ Cherokee Technical Forum 2 03-08-2008 04:27 AM
'00-'01 0331 Head, number location and advice XJ2000 XJ Cherokee Technical Forum 13 12-06-2006 09:42 AM
can someone run a vin number for me?? isenegger XJ Cherokee Technical Forum 6 09-13-2006 05:09 PM
