4.0L Lower end noise? Videos within - JeepForum.com
post #1 of 13 Old 06-05-2012, 11:14 AM Thread Starter
DerMeister
My 2000 xj developed this noise a couple years ago. It seems like a lower end knock that is sometimes hard to hear, but other times is very noticeable. It only does it when up to operating temp, and it sounds louder during the summer.
Mileage is 114,000
Oil is Rotella 15w-40(I used to use 10w-30 but am trying Rotella for the summer months)
Filter is Wix 51515
Oil pressure is great, 25 at idle, 50 at speed. No coolant loss, oil is clean and stays clean.
DerMeister is offline
post #2 of 13 Old 06-05-2012, 01:06 PM
Azzy
Have you done a compression test?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #3 of 13 Old 06-05-2012, 01:27 PM
BassMasterCHS
1993 XJ Cherokee
Does it stay the same under load and deceleration? I have a similar noise that I suspect is a main bearing knock.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #4 of 13 Old 06-05-2012, 02:18 PM
jeepkid03
Winning
jeepkid03's Avatar
That is normal for the 4.0L. Almost every 4.0 I have heard has that slight idle knock. Some do it more than others, especially high mileage motors. Mine has done it since I bought it, my previous '90 made that noise, my dad's '87 made that noise, and my buddy's 2000 also makes the noise. I seem to only notice it in mine when I run a 10w40 oil. 10w30 seems to quiet it down a lot.
Try Pennzoil Yellow Bottle 10w30 and see how that does. It has lots of moly in it, and seems to quiet my 4.0 down.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #5 of 13 Old 06-05-2012, 08:28 PM
Oregon187
Mine is an 01 and it makes the exact same noise. I am hoping that it is normal too, my brother has a ZJ with a 4.0 that also makes the same noise.
2001 XJ build thread --
Oregon187 is offline
post #6 of 13 Old 06-05-2012, 09:20 PM Thread Starter
DerMeister
No, I will be doing a compression, or leak down test in the next few months when I change the plugs and boots.
It goes away under acceleration and it only existent at idle.
Glad to hear this is normal for the most part, does anyone know exactly what it is? I've been keeping an ear on it, but thankfully the noise has stayed the same.
It isn't torque converter bolts either.
post #7 of 13 Old 06-06-2012, 08:11 AM
Oregon187
Yeah, I checked my flex plate bolts and they were fine too.
post #8 of 13 Old 06-06-2012, 06:30 PM
Oregon187
Bump. Anyone else have an opinion on this issue? I'd really like to hear from some more of the experts around here that have owned 4.0's for many years.
post #9 of 13 Old 06-08-2012, 09:49 PM Thread Starter
DerMeister
Another bump, I am interested if anyone knows what it is for sure as well.
post #10 of 13 Old 06-08-2012, 10:01 PM
1CVPaul
1994 XJ Cherokee
So I'm the second owner of mine. PO was anal about keeping records ( bless his heart ). One of the items in the extensive file he had kept on the xj, was a copy of a letter to Chrysler he sent soon after he had purchased it regarding the " knocking at idle ". According to them it is normal. I had heard that it had something to do with a coating that the factory put on the pistons. Mine sounded like a diesel at idle until I rebuilt it. Now, with new pistons and re-bore, it sounds more like a sewing machine. Quite ! Bottom line - nothing to worry about. Typo "quiet"
I'm right 97% of the time. The other 4% doesn't matter.
1CVPaul is offline
post #11 of 13 Old 06-09-2012, 02:26 AM
IndridCold89
1991 XJ Cherokee
Here's mine making that exact same noise. Threads about this help me worry less about it, lol.
IndridCold89 is offline
post #12 of 13 Old 06-09-2012, 05:17 AM
Pats94
I'm makes the same noise, has for a long time, at least 90,000 miles. I chalked it up to piston slap.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #13 of 13 Old 06-07-2013, 08:27 PM
zachm
My 2000xj just started making the same noise at 126k. It only happens at start up. The noise goes away after driving a short distance. I was starting to get worried about it, maybe this is just normal?
zachm is offline
XJ Videos? badtodabone XJ Cherokee Technical Forum 34 06-29-2009 03:42 PM
who here can edit videos?? iwishihad1 XJ Cherokee Technical Forum 2 10-24-2007 04:11 PM
Off road videos? muddy bike XJ Cherokee Technical Forum 4 06-05-2004 11:15 PM
Nasty noise coming from lower motor area.. CherokeeChance XJ Cherokee Technical Forum 9 02-27-2004 01:23 PM
new videos AMK XJ Cherokee Technical Forum 3 09-13-2003 03:19 PM
