4.0L cylinder head replacement...Walkthrough? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 4.0L cylinder head replacement...Walkthrough?
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 06-15-2009, 06:28 PM   #1
MikeMcCasland
Hey Guys,
I'm a Ford guy myself but I'm going to be helping a friend replace the head gasket on his 2000 XJ 4.0L. It has a cracked cylinder head or blow head gasket, but with this specific casting I'm guessing cracked head. It does all the typical things, fouls plugs on the same cylinder constantly, looses coolant, smoke on startup etc.
I'm looking for a detailed walk through with pictures. This stuff is hard to find on some forums but this is the jeep forums, and jeep guys are always tearing apart their trucks for some modification or another. I figured given the number of threads out there regarding this issue there HAD to be someone who wrote up a walk through.
Anyone go something like this?
EDIT: Changed the year. It's a 2000 model.
MikeMcCasland is offline   Reply With Quote
Unread 06-15-2009, 06:59 PM   #2
xjfever
1995 XJ Cherokee
The 99 model should have the better casting, the 00-01 had the 0331 casting which is more prone to cracking.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Unread 06-15-2009, 07:07 PM   #3
MikeMcCasland
Yup, my mistake it's actually a 2000 model.
Unread 06-15-2009, 07:12 PM   #4
xjfever
1995 XJ Cherokee
Don't know if you have found a replacement head or not but I would look into alabama cylinder head. They make a better replacement. I don't have a walk thru but it's basically remove and replace with the proper torque sequence, and adding sealant to the front head bolt that is behind the thermostat housing. I would recommend to your friend getting a factory service manual. It will have all the info you and he needs to do this and many other tasks.
Unread 06-15-2009, 07:20 PM   #5
MikeMcCasland
I have advised him to get a manual like that, at the very least a Haynes manual. Nope have not found a new head yet. He just got the XJ this weekend so hasn't had the time to look yet. Again, I figured you Jeep guys had a write up for everything.
Unread 06-16-2009, 11:42 AM   #6
100dollarbill
100dollarbill's Avatar
1993 XJ Cherokee
I am in the process of replacing my 1993's cylinder head also. Everyone is saying you need sealant on bolt #11. Exactly what kind of sealant (I'm guessing high temp RTV) and where on the bolt do you put it? I know that bolt goes into the water jacket but do you slobber the whole thing with sealant? Wow this is starting to sound like a stupid question.
Originally Posted by Muddeprived View Post
I also have this strange jerk at the steering wheel
Originally Posted by JLC08JK View Post
P.S. please stop bringing up the CAI, Those Government Guys make me nervous!!!
'93 XJ 4 1/2" lift on 33's
'08 JK Unlimited Detonator Yellow DD
'11 Liberty Sport (the wife's)
100dollarbill is offline   Reply With Quote
