4.0L Compression Test Results - JeepForum.com
post #1 of 5 Old 10-18-2009, 12:25 PM Thread Starter
Runner6
1991 XJ Cherokee
The 4.0L is actually in a 1987 MJ, but I thought I'd post it here as well. Hope to get some expert advice.
Had the fuel pump and all fuel injectors professionally replaced, and just completed a compression test. Here's what we came up with:
1 - 65 psi
2 - 90 psi
3 - 90 psi
4 - 60 psi
5 - 90 psi
6 - 80 psi
Although the engine only shows 97K, it was not well-maintained by the previous owner. We changed the oil immediately upon purchase, and the oil was the blackest I've ever seen. It even felt sticky. No telling when the last oil change took place.
Any opinions on what the readings above are telling us?
Thanks.
Runner6 is offline
post #2 of 5 Old 10-18-2009, 12:43 PM
blue96jeep
if i am not mistaken the spec is 120-150 since your specs are below the minimum spec i say you need to rebuild, piston rings are shot, did you do a wet test.
-ryan
blue96jeep is offline
post #3 of 5 Old 10-18-2009, 01:36 PM
Rollin
1 - 65 psi
2 - 90 psi
3 - 90 psi
4 - 60 psi
5 - 90 psi
6 - 80 psi
Thanks.
Supposed to be 150 on a 4.0l. Time for a rebuild with 4.2 rods and a 4.2 crank
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #4 of 5 Old 01-09-2010, 09:46 PM
KevinM90
rings and head gasket?
1996 Jeep Cherokee Sport. 3" lift/31" combo. Some lights. Flowmaster. 5 different horns. Full size spare. No rust. Daily driven. Will be...forever.
KevinM90 is offline
post #5 of 5 Old 01-09-2010, 09:49 PM
KevinM90
double post sorry
KevinM90 is offline
Compression Test Results! 1984XJ XJ Cherokee Technical Forum 5 07-24-2009 06:59 PM
advise needed on compression test results and headgasket crmaverick89 XJ Cherokee Technical Forum 12 07-19-2009 09:52 PM
bad compression results StokedXJ11 XJ Cherokee Technical Forum 1 10-04-2008 02:17 PM
Compression Results XJ4oh XJ Cherokee Technical Forum 0 07-06-2008 02:53 PM
Compression Test Results oj_584 XJ Cherokee Technical Forum 9 05-02-2007 01:17 PM
