4.0HO expansion plugs leaking - JeepForum.com
post #1 of 4 Old 04-16-2017, 08:01 PM Thread Starter
BagusJeep
1981 CJ7
I fixed some leaks at the water pump at New Year but it carried on losing water and I kept on topping it up. I have finally found the time to look a lot closer and the plugs are a mess.
Now taking engine out to get to back of engine.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #2 of 4 Old 04-17-2017, 06:47 AM
dzywicki
If the visible ones look that bad, you are going to want to replace the one on the back of the engine too. I just did this on replacement motor for my '98. Pretty simple. Use a flat blade screwdriver near the lip and knock it into the block. Then use a pair of pliers to pull it out. There are two on the back of the block and 1 on the back of the cylinder head. You have to pull the engine or transmission to get the one on the back of the block. Here is a thread where I replaced mine with brass. https://www.cherokeeforum.com/f2/fre...-4-0-a-234265/
dzywicki is offline
post #3 of 4 Old 04-17-2017, 09:03 PM
ou2mame
I'll be doing this over the summer at some point. Only one of mine is leaking so I'm hoping I can get away with just doing the side ones
Sent from my HTC M9 using Tapatalk
ou2mame is offline
post #4 of 4 Old 04-17-2017, 10:43 PM Thread Starter
BagusJeep
1981 CJ7
I would like to hope the back ones are fine but it is just a question of time, they will not get any better unless replaced.
Thanks for the link dzy, just waiting parts.
