Quantcast 4.0 will turn over not start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 4.0 will turn over not start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-05-2009, 08:26 PM   #1
tminter
1989 XJ Cherokee
on my 89 4.0 after serious mudding will not start I've changed plugs the crank sensor, coil, got fuel will the NSS allow engine to turn over but not crank? or do I need to look else where?
tminter is offline   Reply With Quote
Old 03-05-2009, 08:30 PM   #2
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
The NSS will not let the engine turn over. Have you tested fuel pressure, and spark?
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 03-06-2009, 07:44 AM   #3
tjwalker
It's the crank sensor!
tjwalker's Avatar
xjfever is right; you have to determine what you're missing.
Try spraying some starting fluid into the intake. If it starts and runs momentarily, then you have a fuel delivery problem.
For spark, pull a spark plug and keep it attached to the plug wire. Place the plug electrode near a good engine ground. Have a buddy crank the engine while you watch. You're looking for a strong, blue, snapping spark. Orange/yellow is a weak spark which isn't good.
Once you know what you're missing, the suspect list gets a whole lot shorter. Post back what you find!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 03-06-2009, 08:51 AM   #4
dz1087
I recently had to replace the camshaft position sensor on mine, but it threw a code a few days before completely dying. Had spark, and fuel pressure, but the injectors weren't firing.
I'm still not sure if the aftermarket crank sensor I put on recently the cam sensor or not, but they went out within three weeks of each other. It still takes a long crank to get it going when cold now.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline   Reply With Quote
Old 03-06-2009, 04:11 PM   #5
tminter
1989 XJ Cherokee
fuel isn't the issue i think it is the spark the color was orange/yellow real strong though the spark increased when i changed the coil what causes the spark to be yellow?
Old 03-06-2009, 04:14 PM   #6
tminter
1989 XJ Cherokee
hey guys also I've tried pulling codes on my 89 by turning key off/on I've tried several methods I can't get the check engine light to come on since i can't get it out of my yard what now I could use all of the help
Old 03-06-2009, 04:34 PM   #7
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
You don't have a CEL on the 89. I would change the plug wires, and the distributor cap.
Glock Forum
