4.0 will crank but will not start.... - JeepForum.com
post #1 of 8 Old 07-26-2009, 12:43 PM Thread Starter
MarkwithaK
I recently bought a '98 Cherokee Classic from a good friend. On Christmas Eve he went to move the Jeep and hit a small bump, the vehicle just quit at that point. It would crank but would not start. Eventually he sold the problem to me for a measly $400.00.
I changed out the CPS and still no start. I then replaced the cap and wires with no luck. I found no spark to the cap and eventually found no voltage to the coil itself. I have a strong electrical background and figure to start at the source....I assume that would be the ICM?
While it is unfortunate that I had to find this forum under this circumstance I am glad I have. Thank you in advance for any help.
MarkwithaK is offline
post #2 of 8 Old 07-26-2009, 12:50 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would test all fuses and relays to begin with, then test the cam position sensor under the distributor cap.
xjfever is offline
post #3 of 8 Old 07-26-2009, 01:09 PM Thread Starter
MarkwithaK
Thanks for the info. All fuses and relays have been tested. Forgive my ignorance but even if the cam sensor has failed wouldn't I still get spark from the coil itself?
post #4 of 8 Old 07-26-2009, 01:21 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Yeah, I was distracted when reading the post. You will most likely have to start at the coil and backtrack to find where the voltage is lost.
xjfever is offline
post #5 of 8 Old 07-26-2009, 06:05 PM Thread Starter
MarkwithaK
That is along the line of what I imagined. I read through the wiring schematics in my Haynes manual but it seems to offer up 2 similar yet equally incomplete versions for this year/engine combo. I suspect it to be one of two things (broken wire or failed ECU) but I could be so very wrong.
post #6 of 8 Old 07-26-2009, 07:23 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
Check the harness up to the CPS if its loose it can melt along the exhaust down pipe.
Not sure if your 98 is the same but my coil sits on top of the ignition module, it snaps into contact points underneath the coil maybe there dirty and need cleaning or the module could be bad it self.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #7 of 8 Old 07-26-2009, 08:33 PM Thread Starter
MarkwithaK
The CPS harness shows no signs of damage. My coil actually sits on the passenger side of the engine block. It is bolted to a metal bracket. I did notice that the 2 wires that lead to the plug seemed to be rather tight and may have been creased. Not sure if I'm getting continuity. I was trying to check the wire back to the ECM but the wiring diagram I have is a bit misleading perhaps.
post #8 of 8 Old 07-27-2009, 10:48 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
There is a connector for the crank sensor under the hood back near the firewall/#6 injector. Unplug it and clean it with electrical contact cleaner. If the contacts in that connector are dirty, it can inhibit the crank sensor signal from making it to the computer.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
91 XJ No Crank, No Start 91XJinNC XJ Cherokee Technical Forum 11 05-30-2009 11:21 PM
crank but no start Willy36 XJ Cherokee Technical Forum 1 04-15-2008 10:50 PM
crank crank crank no start lostxj XJ Cherokee Technical Forum 8 04-05-2008 12:36 PM
crank crank no start xj 911tj XJ Cherokee Technical Forum 0 08-04-2007 08:51 PM
crank crank crank then start GDSQDCR MJ Comanche Technical Forum 2 08-29-2005 01:09 PM
